jartsa said:
I meant everything is Lorentz contracted, including fields.
If you are speeding through the universe, measuring the curvature of the space, you can do a curvature map of a large area of the universe in short time. That proves that the areas of curvature are contracted.
There is a way to do something similar like this that actually works. The Riemann curvature tensor descries the curvature of space-time, and one can perform a
local Lorentz boost of this tensor using the usual tensor rules for a rank 4 tensor. Basically one creates a local frame field using local basis vectors, then boosts the basis vectors appropriately.
To go much further one need a physical interpretation of the Riemann curvature tensor. The most important parts of this tensor correspond in normal circumstances to to tidal forces, so one can get a somewhat intuitive idea of how gravity transforms by imagining you boost, not "gravity", but rather "tidal gravity". There are limits to how well this works, as will be discussed below.
There are other components of the Riemann than the so called "electrogravitic" parts that are responsible for tidal forces. These are the parts responsible for frame dragging effects (magnetogravitic parts) and purely spatial distortions (topogravitic parts). So there is already a bit of a disconnect between viewing the Riemann as "just" tidal gravity.
An additional issue is that the "tidal force" interpretation has issues for observers with sufficiently high accelerations, though for reasonable accelerations the errors are minor, for infinite proper accelerations the errors become infinite . This is why the tidal forces for an observer falling into a black hole are finite while the tidal forces for static observers hovering near the event horizon become infinite as one approaches the horizon closer and closer. The Riemann is always finite, to be clear, the issue is that the notion of "tidal forces" is not quite a perfect match for the actual Riemann.
An third problem that raises its head is accounting for gravitational time dilation. Gravitational time dilation does not arise naturally when interpreting gravity as a force - there is no other "forces" other than gravity that causes time dilation, and in fact the existence of gravitational time dilation is one of the observed features of gravity that does not easily fit into the idea that gravity is a force. Gravitational time dilation suggests, instead, that gravity is something else - curved spacetime. The data to show the existence of gravitational time dilation was not there before Einstein, but it is now. Time dilation is now so routinely observed that we have to account for it in precision timekeeping here on the Earth, but its very existence was not suspected until GR predicted it.
Gravitational time dilation does NOT transform as a tensor, even defining it requires defining a coordinate system. (One might regard g_00 as defining time dilation, in which case it does transform as one component of a tensor - but one needs to specify the whole coordinate system to be able to calcuIate that single component). Given a particular coordinate system for the moving observer (such as a Fermi Normal coordinate system), then one can compute the time dilation in that coordinate system, but the process of computation generally turns out to be very difficult in practice, with no closed form solutions, and require a fairly advanced knowledge of the mathematical formalisms of curved space-time. The minimum requirements would be to know the metric tensor, the Riemann tensor, and the geodesic equations, plus knowledge of how to go from the metric tensor to the Christoffel symbols needed for the geodesic equations , and how to go from the meric tensor to the Riemann tensor.
