Does Counterbalancing Weight Differ From Concrete Weight in a Spinning Mould?
When forming a concrete utility pole with an aperture in a spinning mold, the weight of the counterbalance needed differs from the weight of the concrete itself. The counterbalance must account for the mass distribution and dynamics of the spinning process, as it is placed outside the mold. The required counterbalance weight is not simply equal to the concrete's weight of 403 lbs, as the external placement alters the centripetal forces at play. A calculation factor is necessary to determine the appropriate counterbalance weight, considering the physics of the system. Understanding these dynamics is crucial for achieving stability during the spinning process.
lwasmund
I am forming a concrete utility pole centripetaly in the mould (lathe). I need to have it form with an aperature(box shaped hole). I need to place a box to form the hole for the aperature and it needs to be of proper weight. the weight the concrete would of been had there been no aperture. It is best if i place the box in without it being of the desired weight, and counter balance it on the outside of the mould. My question is would the wieght needed to counterbalance the pole when spinning need to be different then the aproximated weight of the concrete(403lbs). Since the weight is on the outside of the mould?
thanks
I understand a little about physics. My main study is civil eng. I am looking for the factor that I can add to my equation to calculate for the difference with the counterbalance being on the outside. think of a ball on a string. except no the ball isn't on a string but held in orbit by the perimeter. How much mass/weight do I need to counterbalance. When it is to counter 403lbs of misplaced concrete.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
