Does light bending doubly violate the equivalence principle?
wisp
The equivalence principle (EP) - which is the basis of general relativity – states that you cannot distinguish between an object’s behaviour in a uniform gravitational field from that in a uniformly accelerating frame.
If light travels vertically in a gravity field it loses or gains energy, and experiments confirm that gravity pulls on light as if it possessed inertial mass m=E/c^2. So light traveling vertically obeys the EP.
When Einstein first calculated the bending of light near the sun he got a value of 0.8 arcsec, using the above reasoning. But later corrected this to 1.75 arcsec, because light refracts in a gravitational field. So the light bends doubly.
Consider the two cases:
1. An astronaut is in a room inside a rocket that is accelerating. A beam of light passes horizontally across the room and strikes the opposite wall lower down by distance d.
2. An astronaut is in a room inside a rocket that is stationary on the earth. A beam of light passes horizontally across the room and strikes the opposite wall lower down.
Does light fall by d (gravity pulling on light’s inertial mass only)?
Or does it fall by 2d (due to refraction and gravitational pull)?
If it’s 2d, doesn’t that violate the EP?
You haven't understood the 'bending of light' in GR properly, don't worry Einstein initially made the same mistake so you are in good company!
There are two components to the angle of deflection, the first is due to the equivalence principle, the falling of the inertial frame of reference, and the second is due to the curvature of space.
In GR each is equal to half the total deflection.
In your example the light 'falls' by d. As the experiment is local the curvature of space is not a factor, it only applies over an extended volume.
Garth
Yes.
When Einstein first calculated the deflection of light it was around a spherically symmetric body (not a uniform g-field). At that time GR was an incomplete theory. Later on it became apparent that the altering of space itself takes part in the delfection. So have the deflection around a star is half E/c^2 and the other half is alterered space.
It's 1-d.
Pete
I’m not convinced that the photon doesn’t fall by 2d.
If a horizontally traveling photon meets a vertically traveling one in the stationary room, we know from the EP that the vertical one will feel the whole pull of gravity on its inertial mass E/c^2. So why should the horizontal one feel only half the pull of gravity?
And if there are a bunch of photons traveling horizontally shouldn’t they refract as their speed slows nearer the Earth, as well as feeling the whole pull of gravity?
Your negeclting the space curvature. Once Einstein realized that he modified his theory so as to take that into account. So now we know that half the deflection is from spatial curvature. If there is no spacetime curvature then there is no spatial deflection since a uniform field has curvature
Pete
It's 1d
Following the logic in http://www.mathpages.com/rr/s6-03/6-03.htm
the effects of gravity on light in a uniform field must pull it down by 1d. And if an equal effect is caused by light refracting in a uniform gravitational field, then it must also refract a further 1d, making 2d in total, and not 1d.
Gravity pull and refraction each account for 1d, which is 1/2 the total 2d.
Now if we take an infinitely small space, the rate of change is still 2 and not 1. So the equivalence principle is false for light bending in a uniform gravity field.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
