Does reflection accompany refraction in Snell's law?
When an incident ray strikes an interface at an angle less than or equal to the Critical Angle, it is primarily refracted, but reflection also occurs. In optics, reflection is generally present unless the angle is at the Brewster angle with appropriate polarization. The discussion highlights that in the context of mechanical waves, such as those used in oil and gas exploration, reflection is likely to occur regardless of wave type or polarization. The conversation raises the question of whether a Brewster angle exists for mechanical waves in geological contexts. Overall, reflection accompanies refraction in Snell's Law applications across different wave types.
Seismic101
If the the angle of incidence of an incident ray is less than (or equal to) the Critical Angle, the ray is refracted, but do we still get some reflection from this same incident ray?
Science news on Phys.org
Hi Seismic101. :welcome:
Reflection like you see from a train window pane at night?
I am not sure. I wasn't really speaking about light although same principles apply, I guess? Please let me explain more.
In my field (O&G Exploration) we send vibrations into the Earth, and when this energy encounters the interface between Earth layers it follows Snell's Law. My question is: when the ray hits the interface at angle less than or equal to the Critical, we get refraction, but do we get some reflected rays as well?
I like the analogy you used! Thanks for the nice welcome!
In optics, when a ray of light hits an interface between two different media, reflection will always take place except for when the incident angle is equal to the Brewster angle and the incoming polarization lies in the incident plane. Since, the wave you are dealing with is of longitudinal waves where polarization is not relevant, I presume reflection will always take place regardless of any condition of the system.
The vibrations (mechanical waves) we send into the Earth can be longitudinal (particle motion in the direction of wave propagation) or transverse (particle motion is perpendicular to the direction of wave propagation).
Do you think this is true for any medium/ wave type? In other words, do you think there is a Brewster angle in the case of mechanical waves propagating through Earth layers?
Thanks for taking the time to reply.
maybe this will help ?
cheers
Dave
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
