Does slimy spit have a spring constant?
Slimy spit exhibits properties similar to viscoelastic materials, allowing it to stretch and recoil like a spring when released. This behavior can be attributed to the surface tension and viscoelasticity of non-Newtonian fluids. Observations indicate that when slimy spit is elongated, it can break and then jump back, demonstrating its elastic characteristics. The discussion highlights the scientific principles behind these phenomena, suggesting that they can be explained through elementary fluid mechanics. Understanding these properties can enhance knowledge of fluid dynamics in biological substances.
bobby2k
Hello
WARNING: Some people may find this post a little gross.
I observed something today that I didn't know could happen in fluids, only in solids. I let some slimy spit out from my mouth. It became a longer and longer connected line, and then the bottom broke off. What was interesting was what happened with the part connected to my mouth. It kind of jumped up again, like a spring that had been stretched. I've never thought about this before. Does slimy fluidshave some kind of spring constant?, can this be explained with elementary fluidmechanics?
A.T. said:
It could be surface tension and/or viscoelasticity exhibited by non-Newtonian fluids:
http://en.wikipedia.org/wiki/Non-Newtonian_fluid
Yes. Mucus and spit are viscoelastic, and exhibit, among other things, the phenomenon of recoil.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
