Does the Diameter of a Barometer Tube Affect the Height of the Mercury Column?
  • Thread starter Thread starter praveenbm5
    Barometer Mercury
The diameter of a barometer tube does not affect the height of the mercury column as long as the inner diameter remains consistent. The key factor influencing the column height is the pressure at the bottom of the column, not the tube's diameter. Changes in diameter, whether tapering or stepped, do not alter the mercury height. The discussion emphasizes that pressure is the sole determinant for the column height. Understanding this principle is crucial for accurate barometric measurements.
praveenbm5
I am curious if the height of the Mercury column inside a Toricellian Mercury Barometer be the same if we use a tapering / stepped (unequal inner diameter [ID]) glass tube as depicted in the image below instead of a regular constant ID one?
Note: I know that the ID of a barometer tube does not affect the Mercury column height as long as the ID of the tube remains the same.
The only relevant thing is the pressure at the bottom of the column, i.e., the height of the column. Whether the diameter changes or not is irrelevant.
Thank you for the quick clarification. Physics Forums rocks :smile:
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
