Does the light transform a matter?
In summary, light can be considered both energy and matter. It can be converted into matter, specifically an electron and positron pair, through the process of pair production. This is the opposite of when an electron and positron annihilate each other and release two gamma rays. Light can also transfer energy when behaving like a wave and transfer momentum when acting like a particle. Its mass is defined as the product of its momentum and the speed of light. This duality makes it a complex and fascinating subject, best suited for the field of physics.
canopus
I've been dwelling on this question for hours! Does the light transform a matter? It seems it does... A high energetic photon transform an electron and a positron. Hmm, how can it transform then?
PS:I guess this subject is much suitable for physics.
Science news on Phys.org
Light is energy and matter is energy... so maybe. Sorry I'm no more help :)
Mass and energy are interchangeable, since light is energy, it can be converted into matter. A very high energetic photon of light (xray, gamma ray) can transform into an electron and positron pair. Light transforming into matter is the opposite of the positron and electron anihhilating each other and being converted into two gamma rays, released in opposite directions.
Thanks for the detailed information. It really helped me!
It is incorrect to say that light is energy. It is correct to say that light has energy.
Pete
Pete
This seems to suggest that light is a thing that has the property, energy. But if you remove all the energy from light, what is left?
Keep on chuggin !
Vern
Nothing is left (;
Who, specifically, is this "you" that you are talking to? If it isn't some omnipotent god, then forget it, because the suggestion of removing all energy from light is not very meaningful.
Light has 0 rest mass, so it is not energy, you have no mass or energy left.
When antimatter and matter annihilate, they are converted into ENERGY...not something that HAS energy. It so happens that this energy is gamma rays. Therefore light IS energy. If light was something that HAD energy, then if it gave away all of its energy to some substance, there would be a stationary photon left...with no energy, and we all know that this can't be, and isn't true at all.
That's like saying that a car as the property of speed. Speed is not an inherent property of a car.
No energy, no photon. That can never be taken to mean that a photon and energy are the same exact thing. There is a one-to-one relationship. That is all. There is a one-to-one relationship between the volume of a sphere and the radius of a sphere. No radius - no sphere. But it is incorrect to say that radius and volume are different names for the same thing.
That is incorrect. See above.
That is incorrect. A photon can give up some of its energy, e.g. by scattering off of an electron. An photon can give up all of its energy by being absorbed by an atom. When it does so the photon no longer exists, it doesn't mean that its at rest.
Pete
Pete
what do you mean. When a matter and its anti matter particle anniahlate, they form pure energy.
one question.
light has 0 rest mass, yes? but light is never at rest... so couldn't you take the mass then as the momentum/c?
but then again, this whole business is quite tricky
No, they form photons. Photons are not "pure energy", they are...well...photons!
PMB had it just right above: Photons are not energy, they have energy.
Photons have spin and parity too, but we don't say that they are "pure spin" or "pure parity". They have those properties, they are not identical to them.
I forgot to mention that pair production from a single photon can't occur in a vaccum. It must occur near the nucleus of an atom. The nucleus sort of acts like a catalyst in that way. If pair production from a single photon occurred in a vacuum then momentum wouldn't be conserved. The nucleas takes up some of that momentum.
Pete
who told you that anniahlation of an atimatter and matter particle produces photons?
QFT and experimental evidence say so. In fact, there's nothing else that a pair can produce when they annihilate, because it would violate known conservation laws.
daveed said:
one question.
No, that would give you the maximum mass into which that photon of light can be transformed into.
daveed said:
one question.
Yes. In fact (relativistic) mass is defined as the m in p = mv. So when v = c -> p = mc or m = p/c.
Pete
re light = energy
Duality. Wouldn't light be considered energy when it is behaving like a wave, and have energy when it acts like a particle?
I wave can transfer energy from one system to another, while a particle can transfer momentum in the form of thermal energy. So when a light 'particle' strikes a photovoltaic cell (solar cell) to generate current, it would be acting like a wave?
Somebody straighten me out here, I am getting lost.
No. The wave part is statisical only. Too much to explain here what that means and I have to log off now. time to rest. More later.
Pete
1. Does light transform matter?
Yes, light can transform matter through a process known as photochemistry. This involves the absorption of light energy by molecules, which can cause them to undergo chemical reactions and transform into different substances.
2. How does light transform matter?
Light can transform matter in various ways, depending on the type of matter and the wavelength of light. Some common mechanisms include the breaking of chemical bonds, the excitation of electrons, and the production of free radicals.
3. What types of matter can be transformed by light?
Light can transform a wide range of matter, including gases, liquids, and solids. Some common examples include the production of oxygen from water through photosynthesis, the bleaching of hair or fabric by sunlight, and the curing of certain materials through UV light exposure.
4. Can light transform matter into different states of matter?
Yes, light can transform matter into different states, such as from solid to liquid or gas. This is often seen in phase transitions, where light energy is absorbed by the molecules and causes them to vibrate or move faster, leading to a change in state.
5. Are there any limitations to light transforming matter?
While light can transform matter in various ways, there are some limitations. For example, the type and intensity of light must be suitable for the specific type of matter and reaction desired. Additionally, other factors such as temperature and pressure can also affect the transformation process.
17K
  • Electrical Engineering
  • Optics
