Does the self-diffusion of H2O18 differ from HDO in groundwater?
The discussion centers on the self-diffusion coefficients of water isotopes, specifically HDO and H2O18. The original inquiry seeks clarification on whether H2O18 diffuses faster than HDO, referencing classic studies by Wang, Robinson, and Edelman from 1952, which indicate that H2O18 has a higher diffusion rate than HDO and HTO. Participants note that while H2O18 is heavier and might be expected to diffuse more slowly, factors such as deuterium exchange and the solvation of cationic species complicate this assumption. The conversation highlights that the diffusion behavior of these isotopes is influenced by their interactions in solution, including the impact of solvation on diffusion rates. Additionally, the effects of ethanol on water's self-diffusion coefficients are mentioned, illustrating how composition changes can affect diffusion dynamics. Overall, the discussion emphasizes the complexity of diffusion processes in isotopic water and the need for careful consideration of various factors when making comparisons.
jean
[SOLVED] self diffusion of water
Hi, I was wondering if anyone could give me a hand- or point in the right direction about a question I have concerning the self diffusion coefficients of HDO vs H2O18. To calculate the effective diffusion coefficients of isotopes of water in groundwater most people use the self-diffusion coefficients in Wang, Robinson and Edelman 1952 in which H2O18>HDO and HTO. I've found more recent references but they compare the diffusion coefficients of D2O and H2O18- I can't seem to find any mention of HDO. So, I guess my questions is; would you expect H2O18 to diffuse faster than HDO?
Thanks!
Chemistry news on Phys.org
Hmm, that;s a good question. H2O18 is heavier than HDO, so in that aspect I would expect to to diffuse more slowly. Furthermore, you can get deuterium exchange, which is quite fast, and one could think it would move faster than the oxygen in the original HDO. I really don't know.
Intuitively, one bets the month's rent & grocery money on HDO or D2O --- and winds up living under a bridge hungry. What's going on? Autoionization allows O and H/D/T species to diffuse almost independently of each other in water --- "but, that means the lighter species are moving more slowly?" Nope --- cationic species in aqueous solution are very heavily solvated --- if one wishes to apply the various models to calculate/predict diffusion coefficients for H+ (or D, or T) it is necessary to include a solvation mass, which is going to be somewhere between four and six waters, if memory serves --- much heavier than the wandering O18H-, which is essentially unsolvated (charge delocalization leaves no real attractive center for solvation).
Had you simply asked which is faster without explaining what perplexed you, I woulda said HDO --- having to think about what let's O18 move faster, I can explain it --- perhaps not correctly, but, methinks this is what you're seeing --- probably more a matter of retardation of H, D, T for whatever fraction of time they spend in the ionized state than anything else.
The self-diffusion coefficient of water has a large drop as the concentration of ethanol increases from 0 to 0.3 and then it nearly keeps constant,while that of ethanol has a minimum around ethanol mole fraction of 0.5.The mutual diffusion coefficient could be divided into two parts,the kinematic factor and the thermodynamic factor.Both the kinematic and thermodynamic factors for ethanol-water mixtures were calculated.It was found that both the numbers of H bonds per water and per ethanol decrease as the mole fraction of ethanol increases. The composition dependences and the relationships between the self-and the mutual diffusion coefficients were further discussed.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
27K
