Does the Thomson Model of the Atom Fail at Large or Small Scattering Angles?
The Thomson model of the atom predicts minimal deflection of alpha particles, suggesting less than 1 degree of scattering. However, experimental results, particularly those from Rutherford's scattering experiments, show that significant deflections occur, especially at large angles. The discussion indicates that the Thomson model fails to account for large angle scattering, while it does not fail at small angles where some deflections are observed. The confusion arises from the relationship between the predictions of the Thomson model and the actual scattering data. Ultimately, the Thomson model is inadequate for explaining large angle scattering observed in experiments.
ColdFusion85
I am to explain whether the Thomson model of the atom fails at large scattering angles or at small ones...I obviously don't want the answer, but just some hints as to how I would determine this. Thanks in advance.
I know that the Thomson model predicts that there should be less than 1 degree of deflection for the alpha particles as they pass through the foil, and the Rutherford scattering formula shows that the number of particles that get deflected with respect to their scattering angle decreases as the scattering angle increases...so I am inclined to think that the Thomson model fails for large scattering angles...but the Rutherford formula clearly shows that most particles do get deflected at smaller angles, albeit not 1 degree...so isn't this agreeing with Thomson anyway? I am confused, please help.
I think the question is asking: what observed scattering angles does the Thomson model fail to predict?
AM
Anyone else? Please help, this is due this afternoon.
It is not that difficult. If the Thomson model predicts small scattering angles and experiment shows that some alpha particles are deflected at small scattering angles, then it doesn't fail at small scattering angles. What the Thomson model does not predict or explain is an alpha particle scattering at large angles. Thomson's model, then, fails to predict the large angle scattering that was actually observed by Rutherford.
AM
is anybody having details of
structure of atom
nuetrons
protons
electrons
thomas model of atom
rutherford model of atom
bohr model of atom
atoms molecules
valencies table
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
