Domain of Quadratic Equations
In summary, the domain of quadratic equations can vary depending on the specific conditions given. For finding a suitable domain for an inverse to exist, there are infinite possibilities such as x≥0, x≤0, or any subset of those intervals. The largest possible domain can be found by looking at the vertex of the parabola and selecting all points on one side of the vertex together with the vertex itself. For both x^2- 4 and 2x^2+ 3, the largest domains are x≥0 and x≤0.
thornluke
37
Hi guys,
I'm really confused in finding the domain of quadratic equations.
For example: when finding a suitable domain so that an inverse exists, why is the domain of x2-4 x>0
whilst,
the domain of 2x2+3 is x≥0
Can the domain of x2-4 be x≥0?
Furthermore, what is the largest domain and how do I know whether or not it is the largest?
Thanks,
Thorn.
Mathematics news on Phys.org
thornluke said:
Hi guys,
whilst,
Thanks,
Thorn.
The assumptions you make for your first question are wrong. The domains of the two functions [itex]x^2- 4[/itex] and [itex]2x^2+ 3[/itex] are not different. There exist an infinite number of domains on which [itex]x^2- 4[/itex] or [itex]2x^2+ 3[/itex] are "one-to-one" and so have inverses. [itex]x\ge 0[/itex] and any subset of that are such domains. So are [itex]x\le 0[/itex] and any subsets of that.
As for finding the largest domain (which is what is normally meant by "domain" without other condition), look at the graph. For these quadratics, the simplest thing to do is to find the vertex of each parabola. For [itex]x^2- 4[/itex], the vertex is (0, -4) and for [itex]2x^2+ 3[/itex], it is (0, 3).
Each parabola "turns back" at its vertex so you have two different x values, on either side of the vertex, with the same y value- the function is not "one to one". As long as your set lies on one side of the vertex, it is a domain on which the function is invertible. A largest possible such domain is all points on one side of the vertex together with the vertex itself. Since the two functions, [itex]x^2- 4[/itex] and [itex]2x^2+ 3[/itex] both have vertex at x= 0, there are two such "largest domains", [itex]x\ge 0[/itex] and [itex]x\le 0[/itex], for both.
Also, since this question has nothing to do with "Abstract and Linear Algebra", I am moving it to "General Math".
1. What is the domain of a quadratic equation?
The domain of a quadratic equation is the set of all possible values for the independent variable, typically represented by the variable x. It is the range of values for which the equation is defined and can produce valid solutions.
2. How do you determine the domain of a quadratic equation?
To determine the domain of a quadratic equation, you must consider the restrictions on the independent variable. For example, if the equation contains a square root, the value inside the square root must be non-negative. Additionally, any values that would make the denominator of a fraction equal to 0 must be excluded from the domain.
3. Can the domain of a quadratic equation be infinite?
Yes, the domain of a quadratic equation can be infinite if there are no restrictions on the independent variable. This means that the equation can produce valid solutions for any real number.
4. What happens if a value is outside of the domain of a quadratic equation?
If a value is outside of the domain of a quadratic equation, it means that it is not a valid input for the equation and thus has no solution. This could happen if the value would result in a negative number under a square root, for example.
5. How can the domain of a quadratic equation be represented?
The domain of a quadratic equation can be represented in a few different ways, such as interval notation, set notation, or a graph. For example, the domain of the equation y = x^2 + 1 can be represented as {x ∈ R} (set notation), (-∞, ∞) (interval notation), or a parabola on a graph that extends indefinitely in both directions on the x-axis.
  • General Math
  • General Math
  • General Math
  • General Math
