~christina~
One mole of helium is enclosed in a cylinder with a movable piston. By placing the cylinder in contact with various reservoirs and also insulating it at proper times, the helium performs a cycle. Compute the internal energy change, heat transferred, and work perfomed for each segment of the cyle and the total amount of each of these quantities for the entire cyle. Assume helium to be an ideal gas.
http://img179.imageshack.us/img179/4843/graphnc4.th.jpg
\Delta U= Q + W
PV= nRT
Q= nC_p \Delta T
Q= nC_v \Delta T
\gamma= C_p / C_v = 1.67
C_v= 3/2R
C_p= 5/2R
B is unknown but not sure how to find it...
I do have Parts:
A=> P= 8.00x10^4Pa, V= 2.00m^3
B=> P= ? V=?
C=> P= 3.00x10^4 Pa, V= 5.00m^3
D=> P= 3.00x10^4 Pa, V= 2.00m^3
For DA which is isovolumetric
w= 0
\Delta U= Q for U
\Delta Q= nCv (T_D-T_A) for finding heat (Q)
\Delta E_{int}= C_v \Delta T => however I'm not given T so what do I do?
do I use PV= nRT and then solve for T since I have P and V ? so
\Delta P V /nR = \Delta T
For CD which is Isobaric
P= constant
W= -P(V_F-V_i) for the internal E
\E_{int}= Q + W for the work
PV= nRT
Q= nCP \Delta T
\E _{int}= ? not sure about this
For the part AB It is isothermic
T= constant
T_A= T_B
\Delta U= nR\Delta T= 0 internal Energy which is = 0
so based on above Q= -W to find the heat
P_A= 8.00x10^4 Pa
P_A= 2.00 m^3
W= nRT ( /frac{V_A} {V_B}) => don't have V for the final VB
For part BC
It's adiabatic so Q= 0 thus
\Delta U= W
point B is not known (P or V) initial point
P_iV_i^{\gamma} = P_iV_f^{\gamma}
not sure how to find the \Delta U and that would also = W but if I don't find those then how can I find the W?
Point B
I don't have the P or V for point B so I'm not exactly sure how to find the info I need.
I think that for the \Delta U= 0
P_iV_i^{\gamma} = P_fV_f^{\gamma}
so I think I can find the V and P. But don't you have to be given \gamma ? or is it a constant?
Well after finding the Pf I was thinking of using the fact that the AB is isothermic and plugging into this..
Q= W= P_AV_A ln (V_B/V_A)
Is this it..I think so but I think I'm missing some things here and there on actually solving this with numbers.
Could someone check it for me?
Thank you.
