Doppler effect: moving medium.
In summary, the frequency of sound waves emitted by a source and detected by an observer remains unchanged, even when the medium between them is moving at a particular velocity. This is because the wavefronts travel at a combined speed of the speed of sound and the velocity of the medium, resulting in a constant period between wavefronts. This means that the frequency detected by the observer remains unchanged, regardless of the travel time.
mathman44
207
Hi all. I am asking for some help with getting a physical intuition for the following situation:
Consider an observer and source, at rest. The source emits sound waves of a particular frequency, 'f'. Letting the medium (air for example) between the source and the observer move with a particular velocity, why is it that the frequency of the emitted waves, as detected by the observer, remains unchanged?
It is intuitively clear that the velocity of the emitted wave increases as the medium gains speed, but it is less clear why the frequency detected by the observer remains unchanged.
We all know from experience that the sounds in the distance, traveling through moving air, don't get modified in frequency. But why must this be so, physically?
Any insight would be greatly appreciated!
Say the speed of sound is v, and the flow rate of air is u. The distance between source and observer is d, which is fixed. The source generates a sound with frequency f. The period is T = 1/f.
The wavefronts leaving the source travel at speed v relative to the air, and the air travels at speed u relative to the source and the observer. So the wavefront travels at speed v + u between the source and observer. That means that wavefront 1, leaving at t = 0, arrives at time t1 = d/(v+u) later.
If wavefront 2 leaves at time t = T, it arrives a time t2 = T + d/(v+u) later.
t2 - t1 = T + d/(v+u) - d/(v+u) = T
So... the spacing at which the observer receives the wavefronts is still T and is unaffected by the travel time, it would seem.
1. What is the Doppler effect in a moving medium?
The Doppler effect in a moving medium is the change in frequency of a wave when the source of the wave is moving towards or away from an observer. This results in a perceived shift in the wavelength of the wave.
2. How does the Doppler effect in a moving medium occur?
The Doppler effect in a moving medium occurs because of the relative motion between the source of the wave and the observer. When the source is moving towards the observer, the perceived frequency is higher, and when the source is moving away, the perceived frequency is lower.
3. What happens to the wavelength during the Doppler effect in a moving medium?
The wavelength of a wave is compressed when the source is moving towards the observer, resulting in a shorter perceived wavelength. Conversely, when the source is moving away, the wavelength is stretched, resulting in a longer perceived wavelength.
4. How does the speed of the medium affect the Doppler effect?
The speed of the medium has a direct impact on the magnitude of the Doppler effect. If the medium is moving towards the observer, the effect will be greater, resulting in a higher perceived frequency shift. Similarly, if the medium is moving away, the effect will be smaller, resulting in a lower perceived frequency shift.
5. What are some real-life applications of the Doppler effect in a moving medium?
The Doppler effect in a moving medium has several real-life applications, such as in radar technology, where the frequency shift can help determine the speed and direction of moving objects. It is also used in medical imaging, such as ultrasound, to measure blood flow and detect abnormalities. Additionally, the Doppler effect is used in astronomy to study the motion of celestial bodies.
  • Other Physics Topics
  • Classical Physics
  • Quantum Physics
