What is the Difference Between Dot and Cross Products in Vector Calculations?
The dot product of two vectors results in a scalar, while the cross product yields a vector. In the expression a.(b x c), the cross product must be calculated first before performing the dot product with vector a. The operation cannot be simplified by distributing the dot product over the cross product, as the cross product is only defined for vectors. Therefore, the correct order of operations is to compute b x c first, then take the dot product with a. Understanding these distinctions is crucial for accurate vector calculations.
brandy
dot product and cross product. i (think dot product is like eg (1,2,4).(2,4,5) = 30 and cross product is like eg(1,2,4)x(2,4,5)=2, 8, 20) but I am not sure... and is there an order like in a.bxc do u do bxc and then.a or do u go normal left to right. but if left to right what's the rule in when u multiply one number by a coordinante or vector...
please help
A dot product operation on two vectors results in a scalar i.e. a number [not a vector]. Whereas, the cross product always results in a vector. As for a.(b x c), you CANNOT open the bracket as: (a.b x a.c). This is because cross product is operation that is done on vectors and not on scalars, whereas both, a.b and a.c are scalars.
So, you have to first find out the cross product of b & c, and then solve for the dot product of the resultant vector and a to get your answer.
thanks for clearing that up :smile:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
