Finding the Ratio and Height of a Double Ball Drop Collision
  • Thread starter Thread starter Puddles
    Ball Drop Ratio
The discussion revolves around a physics problem involving two balls dropped from a height, where one ball rebounds elastically from the floor and the other rebounds from it. The main inquiry is to determine the mass ratio m1/M2 that causes the second ball (M2) to stop upon collision with the first ball (m1) and the height m1 subsequently reaches. The participant attempts to apply conservation of momentum and energy but struggles with the math, suspecting an error since the expected ratio is 3:1. Feedback highlights the importance of correctly applying the condition that M2 stops after the collision and questions the choice of positive direction in the equations. Clarification on these points is essential for solving the problem accurately.
Puddles
A ball of mass m1 is aligned above a ball of mass M2 (with slight separation), and the two are dropped simultaneously from height h. (Assume the radius of each ball is negligible compared to h.) (a) If M2 rebounds elastically from the floor and then m1 rebounds from M2, what ratio m1/M2 results in M2 stopping upon its collision with m1? (b) What height h does m1 reach?
KE = .5mv^2
P = mv
Okay, so I drew a diagram and used cons. of momentum and energy to find VM for both and set them equal to each other, but there's something wrong in my math because I know my ratio should be 3:1 and I'm not getting that. Here's what I did as best as I can type out on a computer:
Cons. Momentum)
Pi=Pf
(m1-M2) sqrt(ugh)=m1v+M2V, with (m1-M2) because M2 has a negative momentum after it strikes the ground
((m1-M2) sqrt(2gh) - m1v)/M2 = V
Cons. Energy)
1/2(m1+M2)(sqrt(2gh))^2 = 1/2(m1v^2) + 1/2(M2V^2)
sqrt( (2gh(m1+M2)-mv^2)/M2) = V
I think it's a math issue since when I'm setting them equal to each other my work is only getting more complex…
I don't know what I'm doing wrong because I thought my equations were okay, so if someone could explain how you get through this I would be very thankful.
Hi Pud,
I have difficulty understanding why you set the equations equal to each other. Where do you use the given that M2 stops after colliding with m1 ?
As BvU writes, you have not used that M2 stops. But I wonder about the signs in your first equation. Which direction are you taking as positive?
