Double integral in polar coordination
7 replies · 2K views · last reply
rado5
Handwritten solution of a double integral in polar coordinates, with a small sketch of the region between y = x and y = x^2 in the first quadrant, and the polar limits pi/4 to 0 and sin(theta)/cos^2(theta) to 0 written beside the work.
Please tell me if I am wrong. I suspect about the ranges. Are my range corrrect?
  • Handwritten solution to a double integral in polar coordinates with a small sketch of the region between y = x and y = x^2 for 0 to 1, showing the integral of (x^2+y^2)^(-1/2) with limits converted to polar form and the result written as sqrt(2) - 1.
If you have a double integral on the form I = [tex]\int \int_{R} f(x,y) dy dx[/tex]
Then if you to integrate using polar coordinates then it changes to
I = [tex]\int \int_{R} f(x,y) dA[/tex] where
[tex]dA = r dr d\theta[/tex]
trying adding this and see if you don't get the right result.
Dear Susanne217,
Thank you very much for your reply, but i have already added [tex]dA = r dr d\theta[/tex]
to get the result. If you calculate it you will see that I had already added it! But my problem is the ranges. I suspect about the ranges.
The quantity you integrate (that is '1') is always positive.
An integral is basically a sum, so a sum of positive terms cannot turn into something negative.
The result of the book [tex](1-\sqrt2 \cong -0.41)[/tex] is negative, so it is wrong.
[tex]=\int_0^{\pi/4} \int_{0}^{\frac{sen\theta}{cos^2\theta}} dr\: d\theta[/tex]
[tex]=\int_0^{\pi/4} {\frac{sen\theta}{cos^2\theta}} \: d\theta[/tex]
[tex]=\left[{\frac{1}{cos\theta}\right]_0^{\pi/4}[/tex]
[tex]=\sqrt2-1[/tex]
Your result is ok.
Thank you very much for the notification about "positive". But would you please tell me what your idea is about the ranges? especially about the ranges of "r". Are you sure that my ranges are correct?
Yes they are correct because in a polar-cartesian system:
the system
[tex]y = x tg\theta[/tex]
[tex]y = x^2[/tex]
gives [tex]x = tg\theta[/tex]
[tex]r = \sqrt(x^2+y^2)= tg\theta \sqrt(tg^2\theta+1) = tg\theta / cos\theta = sen\theta / cos^2\theta[/tex]
Handwritten notes showing a sketch of the region between y = x and y = x^2 for 0 to 1, with two double integrals over it: Cartesian integral from 0 to 1 and x^2 to x of dy dx = 1/6, and polar integral from 0 to pi/4 and 0 to sin(theta)/cos^2(theta) of r dr dtheta = 1/6.
  • Handwritten note with a small sketch of a region bounded by the x-axis, the line x = 1 and a curve in the first quadrant, shaded. Cartesian area integral from 0 to 1 of integral x squared to x of dy dx equals 1/6, and polar area integral from 0 to pi/4 of integral 0 to sin theta over cos squared theta of r dr dtheta equals 1/6.
