Understanding Symmetry in Double Integrals
The discussion focuses on evaluating a double integral over a triangular domain defined by the inequalities 0 ≤ y ≤ 3 and (y/3) - 1 ≤ x ≤ 1 - (y/3). The integral in question is ∫∫ (e - x^5 e^(√(1+y^2))) dA. It is established that the x^5 term evaluates to zero due to symmetry, specifically because integrating an odd function over a symmetric interval results in zero. The remaining integral simplifies to 3e, derived from the area of the triangular domain multiplied by the constant e.
  • Understanding of double integrals and their properties
  • Familiarity with symmetry in integrals, particularly odd and even functions
  • Knowledge of triangular domains in calculus
  • Proficiency in using LaTeX for mathematical expressions
  • Study the properties of odd and even functions in integral calculus
  • Learn how to set up and evaluate double integrals over various geometric shapes
  • Explore the concept of symmetry in higher dimensions and its implications in integration
  • Practice using LaTeX for writing complex mathematical expressions accurately
Students and educators in calculus, particularly those focusing on double integrals and symmetry in mathematical analysis.
Linday12
Let D be the triangular domain given by 0\leq y \leq3, (y/3)-1 \leq 1-(y/3). Then
\int\int (e-x^{5}e^(sqrt(1+y^2))
There is a quick way to solve it by breaking apart the double integral and then, apparently the x^5 part goes to 0, by symmetry? Anyways, I'm not sure why.
Then I'm left with the double integral of e, and since the domain is just an isosceles triangle, I can multiply the area of it by the e(constant) to get 3e.
So my question is, why does that other part go to zero? I can't visualize it. Knowing this would be a great help. Thank you! (And sorry about the latex, I couldn't quite work it out)
Is the integral supposed to be
\iint_R e - x^5 e^{\sqrt{1+y^2}}dA
and is the region supposed to be
\frac y 3- 1 \le x \le 1 - \frac y 3
If so, yes, it is because of the x5. When you integrate an odd power of x over a symmetric interval [-a,a] you get 0. Set it up as a dx dy integral and you will see.
Yes, that is it. I will make sure to do that. Thank you very much!
  • · Replies 19 ·
  • · Replies 105 ·
  • · Replies 17 ·
  • · Replies 27 ·
