Kris1120
- 42
White light spans the wavelength range be-
tween about 400 nm and 700 nm.
If white light passes through two slits
0.656 mm apart and falls on a screen 1.7 m
from the slits, what is the distance between
the first-order violet and the first-order red
fringes?
Answer in units of mm.
sin(theta) = m*lambda / d
x = L*tan(theta)
I used the first equation to solve for theta for both red light (lambda = 700 nm) which gave theta = .061139 and violet light (lambda = 400 nm) which gave theta = .034936. I used the second equation to plug in theta and solve for x for each of them. I then subtracted the x value of violet from the x value for red and converted to mm. My final answer was 6.781 mm.
