Understanding Double Slit Interference: Finding Distance to Screen
  • Thread starter Thread starter cathy
The discussion focuses on solving a double slit interference problem involving slit spacing and light wavelength to determine the distance to the screen. Participants express confusion about the origin of the factor 1/4 in the model answer and seek clarification on the intensity diagram's relevance. Key points include understanding that maxima correspond to path differences of nλ and that zero intensity occurs at (2n+1)λ/2. The conversation emphasizes the importance of recognizing the relationship between fringe width and path differences in the context of Young's double slit experiment. Overall, the explanations provided help clarify the concepts necessary to solve the problem effectively.
cathy
The figure shows the light intensity on a screen behind a double slit. The slit spacing is 0.20 mm and the wavelength of the light is 600 nm. What is the distance from the slits to the screen?
This is the figure
http://session.masteringphysics.com/problemAsset/1020631/6/jfk.Figure.17.P38.jpg
2. The attempt at a solution
I have the answer there (attached thumbnail) from what the teacher provided, but I do not understand where 1/4 came from. Will someone please explain this to me? I am very confused. I am also confused on how the intensity diagram shown is used.
To understand a model answer - 1st ignore it and use your own understanding to complete the problem yourself.
Just work through the problem and you'll see why you need the intensity pic.
http://imgur.com/XFvgXj7
This is the model answer.
Would you be able to explain to me where the 1/4 came from? I understand every other part except for that.
And I now understand that the intensity is just to show me the .20 mm
I know that Idouble= I 1(4)
Would it have something to with that? If so, how?
This is the figure
First let me make clear what does this intensity diagram depict:
1) The maxima i.e, the tip of the mountain/curve signifies that at that position the intensity is maximum or, the path difference between the light rays of two sources is n\lambda
2) The points where the graph touches the x-axis is where the intensity is zero, i.e, the paths difference is (2n+1)\lambda/2
3) Note that, the distance between the 1^{st} maxima/tip of the mountain and the 5^{th} tip is 2cm. And there are 4 gaps between the first and the 5th. So, if 4 gaps amount to a width of 2cm, then 1 gap is (1/4)*2.0 cm wide.
I hope you got it now. Do notify if you need any further help.
Happy to help you!
ADI.
Likes 1 person
Thank you so much for explaining everything. I understand it a bit better. Just another question, when the intensity is 0, will (2n+1)\lambda/2 always be the path difference?
For some reason, my textbook is giving me the equation
(m+1)\lambda/L / d
and m\lambda/L /d
subtracted to give \lambda/L /d
For zero intensity, you need 100% destructive interference ... that means that the trough of one wave matches with the peak of the other. So - yeah.
YES.
Resultant intensity from two sources of intensities I_{1} and I_{2} is given by:
I_{resultant} = I_{1} + I_{2} + 2\sqrt{I_{1}*I_{2}}cosø
where ø = Phase difference between the two waves
Since the slits are equidistant from the source, I_{1} = I_{2}
Now you have the formulae with you; think when and at what ø will I_{resultant} be zero.
Likes 1 person
(m+1)\lambda/L / d
and m\lambda/L /d
m\lambda/L represents the height from the central maximum where there is a bright fringe due to a path difference of m\lambda. Similarly m+1\lambda/L corresponds to the height from the central maximum where there is a bright fringe due to a path difference of m+1\lambda.
So the fringe width = distance between the above two fringes = \lambda/L
P.S : I think you need to revisit your class notes/ source for a clearer understanding of Young's double slit experiment. Or else, you can watch these videos:
http://www.youtube.com/watch?v=_N5Y9PVxHLY&list=PLLUpvzaZLf3KRRaeMVudt1G-iuclmAbfw
Okay, I understand.
Thank you everyone.
Okay, I understand.
Thank you everyone.
Thank you!
Thank you! Now I understand how to do this problem!
