How to Calculate Thermal Expansion in a Rod of Length 'l'?
To calculate the thermal expansion of a rod of length 'l' when heated, the increase in length can be expressed as l\alphat, resulting in a new length l1 = l + l\alphat. When the rod is heated again by the same temperature increase 't', the total length l2 can be calculated using two methods, leading to the equations l2 = l1 + l1\alpha t and l2 = l + l\alpha(2t). The discussion reveals that the coefficient of thermal expansion, α, can vary with temperature, but for small temperature changes, the quadratic term can often be neglected. A more accurate approach involves using differential equations to express the relationship between length and temperature, ultimately leading to the exponential form l2 = l0 e^{\alpha 2t}.
Puneeth423
Consider a rod of length 'l'. When heated, its temperature got increased by 't'.
Increase in its length = l\alphat.
total length be (l1) = l + l\alphat.
Again the rod is heated and the temperature further got increased by 't'.
Total length be l2.
l2 can be calculated in two ways,
l2 = l1 + l1\alpha t...(a)
0r l2 = l + l\alpha(2t)...(b)
Equating (a) and (b).
l1 + l1\alpha t = l+l\alpha(2t)
{l + l\alphat} + {l + l\alphat}{\alpha t}
= l+l\alpha(2t).
Solving above equation we get l(\alphat)2 = 0.
Where am i going wrong?
Science news on Phys.org
Your equation b is wrong.
What is wrong?
Initial length of rod is 'l' and total rise in temperature is '2t'.
Its perfect.
The coefficient of expansion varies with temperature. For most substances and practical temperature ranges the variation is small, as is the quadratic term in your calculations.
Since, \alpha is small,\alpha2 can be neglected and can be considered zero.
The formula l1 = l + l\alphat works only for very small t. Correct way to look after sweep over finite temperature range would be as follows.
l+dl = l + l \alpha dt
Where dl is a small change in length, and dt is a small change in temperature. You can rearrange that into a differential equation.
dl/dt = l \alpha
And that's easily solved.
l_1 = l_0 e^{\alpha t}
Now if you substitute this into your formula, it works either way.
l_2 = l_1 e^{\alpha t} = l_0 e^{\alpha t + \alpha t} = l_0 e^{\alpha 2t}
