How Is Drift Calculated in River Boat Problems?
  • Context: Undergrad
  • Thread starter Thread starter gracy
    Boat Drift River
The discussion revolves around the concept of "drift" in river boat problems, exploring its definition, calculation methods, and the implications of different velocities involved in such scenarios. Participants examine how drift is influenced by the river's current and the boat's velocity, with references to specific video content and personal interpretations of the term.
  • Some participants question the definition of drift, suggesting it may not be well-defined in boating problems.
  • One participant proposes that drift is the distance a boat is moved downstream by the river's current, even when the boat is using its engine.
  • Another participant emphasizes the importance of understanding the vector relationships between the boat's velocity and the river's current to calculate drift accurately.
  • There are differing views on how to calculate drift, with some suggesting it should include the countering velocity of the boat while others argue it should only consider the river's velocity.
  • One participant mentions the use of a general equation for relative velocities in boating problems, indicating a preference for a consistent labeling convention.
  • Several participants discuss the concept of relative velocity, particularly in the context of stationary and moving objects, and how it relates to the notion of approach and separation.
Participants express differing opinions on the definition and calculation of drift, with no consensus reached on the correct approach. Some participants agree on the need for clarity in terminology and vector relationships, while others highlight the ambiguity in practical versus theoretical interpretations.
Limitations include varying definitions of drift, dependence on specific problem contexts, and unresolved mathematical steps regarding relative velocities and their implications in different scenarios.
This discussion may be useful for students and practitioners in physics, engineering, and navigation who are interested in the complexities of motion in fluid dynamics and the application of vector analysis in real-world problems.
  • #31
gracy said:
A man and river are moving with same velocity u..
I assume you mean that the man moves with speed u with respect to the river, and the river moves with speed u with respect to the ground.
gracy said:
A person is at point B initially.His velocity with respect to river is always towards point A.River has velocity in horizontal direction.So that person's path is shown as BC.At one instant D I have shown person's velocity withg respect to river as u and component of river's velocity as u Sin theta.
{cos (90-theta) =sin theta.}
I assume the river moves to the right, call it the +x direction. And the man swims so that his velocity with respect to the water is always up, call that the +y direction. So his velocity with respect to the ground is ##u\hat{x} + u\hat{y}##. And since he's moving away from B, that will be his separation velocity from B. (He's moving away from B, not toward B.)
If I have the wrong setup, let me know.
gracy said:
So my teacher said that velocity of approach of person towards B is u-u sin theta.
I do not see where that came from.
gracy said:
Shouldn't then velocity of approach of person towards B be "u"?
Not if I understand the problem statement.
I'm not sure I understand all the arrows in your diagram.
  • #32
Yes ,your assumption is correct.
  • #33
No.And the man swims so that his velocity with respect to the water is always towards A.
  • #34
Actually I think the following image will explain why BC is path of the swimmer/person.
I have changed this a little bit.That's why refer image of my post #36 rather than the one below.
  • #35
That's what I wanted to ask ,so I asked in my post #13
gracy said:
So If I would say A is moving with velocity 5 m/s with respect to ground along the line joining AB.And B is at rest ,what is velocity approach ,of A with respect to B? it will be 5 m/s ?
Because here point A is stationary,and swimmer is going towards it with velocity u along the lining the two.So his approach velocity towards A should be u - 0=u.
But as my teacher had taken his approach velocity u - u sin theta giving the following explanation.
As you can see the image of my post #30
component of river velocity in direction opposite to that of velocity of swimmer is u cos (90- theta)=u sin theta
Note:-y and x are my coordinates in the image of #30.
So over all velocity of approach (u - u sin theta) - 0=u - u sin theta
So I was having confusion whether we can include other velocities if present in the same direction or opposite to the direction of the line joining the person/swimmer and point A.
That's why I asked the below question in my post # 19
gracy said:
If I would say A is moving with velocity 5 m/s with respect to ground along the line joining AB.And B is at rest.There is some another point C which has a component of velocity 3 m/s in opposite direction to line AB. ,what is velocity approach of A with respect to B? Will it be 2 m/s?
  • #36
  • #37
Ah, that's quite different.
Realize that since the velocity of the man with respect to the water continually changes, so that he always points towards A, his path cannot be a straight line BC.
  • #38
Yes.
  • #39
Did you get what am I actually asking?
  • #40
But it will be along BC but not that much straight as I have shown.
  • #41
No. You forgot to include the velocity of the water with respect to the ground in your calculation. Your teacher did not forget that, which is where the u sin(theta) comes from. You need to consider the velocity of the man with respect to A, not just his velocity with respect to the water.
OK.
All that matters is the velocity of the man with respect to the ground. I don't know what other velocities you have in mind.
  • #42
Velocity of swimmer with respect to ground=velocity of swimmer with respect to river+river velocity with (respect to ground)
To get Velocity of approach of swimmer with respect to point A ,component of velocity of swimmer with respect to river along the line joining swimmer and point A i.e u here will have to be added with component of river velocity along the line joining swimmer and point A i.e u sintheta .
As u and u sin theta are in opposite direction there is u +(-u sin theta)- 0 =u - u sin theta.
Right?
  • #43
But why approach velocity has to be calculated in ground frame?
  • #44
Right?
Right.
It doesn't have to be.
You can also calculate it from the frame of the man, but realize that then point A is no longer stationary.
  • #45
That means velocity of A is only zero with respect to ground.Velocity of A with respect to swimmer/man is negative of man's velocity ,right?
  • #46
Right.
  • #47
But I am not getting how it gives u -u sin theta?
  • #48
Perhaps it would help if you first looked up some examples of how Vectors are used in Force problems. Forces seem to be easier to grasp intuitively. Once you are familiar with how resolving forces can be used to solve problems easily, you could move on to velocities because the world of Vectors is the same, wherever they are applied.
  • #49
I am really not getting from where u-usin theta is coming in frame of the swimmer.
  • #50
I would not try to solve such a problem in the frame of the swimmer, in any case. But, if you really want to, the angle theta could be relative to the 'forward direction' of the swimmer - which would be the only logical reference axis if you are truly working in the swimmer's frame. 'The system' will allow you to choose any frame you like but why not choose the most convenient one (i.e. the Earth)?
  • #51
I did not understand.
  • #52
Well, what do you mean by the "frame of the swimmer"? A frame has to specify all coordinates, relative to the swimmer. The swimmer would not 'see' cartesian graph paper, lined up along and normal got the river bank. All he could do would be to put his own graph paper with x and y co ordinates parallel and at right angles to his motion through the water (or some other arbitrary orientation). I was just pointing out how difficult / unsuitable it would be to work with the swimmer's reference frame, compared with using the Earth's frame. Why not make it easy on yourself and go for the obvious way to solve this?
  • #53
velocity approach of A with respect to B is 5 m/s. I don't think point C will matter.
  • · Replies 33 ·
  • · Replies 26 ·
11K
  • · Replies 22 ·
