Drift Speed of Electrons in Conductor with Applied Field
In summary, when an electron is randomly moving inside a conductor and an external electric field is applied, the electrons will begin to move with a net speed called drift speed, against the direction of the field. This drift speed is determined by the acceleration of the electrons and the mean time between consecutive collisions. However, the acceleration is not constant and the drift speed may vary depending on the type of electric field applied. The concept of drift speed is already an average since each electron is constantly interacting with the material and the applied field. This behavior can be described using classical models and transport coefficients, or through more complex quantum calculations.
person_random_normal
164
for an electron, randomly moving inside a conductor , having applied an external electric field we have those electrons moving with a net speed called drift speed , against the direction of field.
so initially as electrons are moving randomly we consider their initial velocity o
and after time t =at
where a = acc. of electrons = e(field)/mass of electron
t = mean time between consecutive collisions of electrons
courtesy PHYSICS by halliday resnick krane vol 2
but i don't understand why don't we average the initial and final speed of electrons ie
drift speed = (0 + at)/2
The acceleration of an electron in a real conductor is not constant. I think when subjected to an electric field, the speed of the electrons increases monotonically up to its "steady-state" drift velocity. If the applied field is not changing (DC), then after an initial transient time, the electrons are flowing at the drift velocity. If the applied field is a sinusoidal function (AC), then the current (and thus drift velocity) will also vary sinusoidally. An accelerating charge (i.e. a varying current) establishes an electromagnetic wave.
I think drift speed is already an average since every electron will be moving at different speeds and constantly interacting with the material and the applied field.
For the acceleration happened just a moment (average), the drift velocity is the average speed electrons have in the conductor after the generation of the electric field.
The electron in a (normal) conductor is under the influence of the electromagnetic force and to a friction force. The notion of a friction force is already a coarse grained description of the full complicated dynamics of the many-body (quantum!) system. On the level of linear-response theory you come astonishingly far with very simple classical pictures introducing some phenomenological transport coefficients (like electric conductivity) and response functions. On a microscopic level, you have to calculate appropriate correlation functions in statistical many-body QFT. See Landau-Lifshitz vol. X for a very good introduction into both classical and quantum transport phenomena.
1. What is drift speed of electrons in a conductor with applied field?
The drift speed of electrons in a conductor with an applied electric field refers to the average velocity at which electrons move through the conductor in response to the applied field. This speed is typically quite slow, on the order of millimeters per second, due to the collisions between electrons and the atoms of the conductor material.
2. How does the applied field affect the drift speed of electrons?
The applied electric field directly affects the drift speed of electrons by providing a force that causes the electrons to move. The stronger the applied field, the greater the force on the electrons, and thus the higher the drift speed. Inversely, a weaker applied field will result in a slower drift speed.
3. What factors impact the drift speed of electrons in a conductor?
The drift speed of electrons in a conductor is influenced by several factors, including the magnitude of the applied field, the type and density of the conductor material, and the temperature of the conductor. These factors can affect the collisions between electrons and atoms, which in turn affect the overall drift speed.
4. Can the drift speed of electrons in a conductor ever reach the speed of light?
No, the drift speed of electrons in a conductor can never reach the speed of light. This is because the speed of light is the maximum speed at which any object can travel, and the drift speed of electrons is limited by the collisions and interactions within the conductor material.
5. How is the drift speed of electrons related to electric current?
The drift speed of electrons is directly related to the flow of electric current in a conductor. As the electrons move through the conductor, they carry charge and create an electric current. The higher the drift speed of electrons, the higher the electric current flow.
  • Electromagnetism
17K
  • Electromagnetism
