Drive Died (arcing between pins on the PCBA)
  • Thread starter Thread starter MaintenanceMGR
    Drive
A drive in a production area has failed multiple times due to arcing between two closely spaced inputs on a control board, raising concerns about potential contamination or gases causing the issue. The environment is clean and dry, and the drive operates at a low voltage of 480V, which typically does not support arcing at such short distances. Suggestions include examining the area for contamination, considering cleaning and conformal coating, and investigating if any environmental changes occurred before the failures. The possibility of manufacturing defects, such as tin whiskers from lead-free solder, is also noted as a potential cause. Overall, further investigation into the specific conditions and components involved is necessary to determine the root cause of the arcing.
MaintenanceMGR
Hello:
I have a problem with a drive located in a small production area. It has failed three times due to arcing between two inputs to a control board. These inputs are about 5mm apart and the manufacturer is saying that this could be from material collecting on these terminals or from gases. Now I can understand material conducting between the inputs, but gases seems rather far fetched. The drive is not sealed and it is at regular atmospheric pressure and cooled with a small muffin fan. The drive does not use any high voltage conversion and the input voltage is only 480V. I remember that it usually takes about 3000V/mm for a spark to develop in air, but I can't find any thing in that range in the drive.
My question is it possible for an arc to develop spontaneously between to points 5mm apart? And if it is what are some examples of voltage or gases that may be present to facilitate such an event.
BTW: Please forgive my ignorance on some of this, I know enough only to get things wrong.
MaintenanceMGR said:
Hello:
Welcome to the PF.
If the atmosphere is wet and dusty, there could be an accumulation of gunk that helps the arc to happen. Do you see evidence of contamination in other areas of that PCB assembly? Have you considered cleaning and conformally coating the PCBA in that area?
Welcome to the PF.
The area is pretty clean and not wet. Specifically the area is a show area for customers that does small production runs, so they keep up with standards very well. Also the drive has been installed for 6 months, and recently the original failed and then two replacements failed as well, within 2 weeks from start to finish. So contamination could have caused the first but the succeeding two, ??
Also we have conducted a study on the incoming power feed, which had nothing of note within a ten day study. My gut is telling me this could be manufacturing issue, but I don't want to take a stand on this without a better understanding of the science and how arc's can form.
How can you be sure that it was arcing between those 2 pins that caused the failures? Was anything else changed in the environment around the drive shortly before the first one failed? Like a new piece of equipment being used/installed nearby?
Can you post a picture of the pins you are talking about?
Lead free solder is notorious for "whiskers". Search on "tin whiskers"
http://nepp.nasa.gov/whisker/Is the arc-over right at a soldered joint?
If so,
Try applying a dab of "Glyptol" insulating paint, or ordinary polyurethane woodworker's varnish (oil based) over the solder pads on the next board.
I'd guess 480 makes quite a flash when it goes. Current limiting fuses like Shawmut 101 might help preserve some clues.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
