Dry water - Sapphire/Novec fire suppressant
  • Thread starter Thread starter DaveC426913
    Fire Water
Novec 1230, also known as Sapphire by Ansul, is a new material developed by 3M that mimics water in appearance and behavior but is non-conductive and non-destructive. It evaporates approximately 25 times faster than water, leading to a cold sensation upon contact and rapid evaporation similar to alcohol. Concerns arise regarding its handling, as it may be absorbed through the skin and has potential health hazards that are often downplayed in marketing. The normal boiling point of Novec 1230 is 49°C, suggesting it may behave like chloroform. While it does not burn when mixed with air, it can evaporate and carry away significant combustion heat, making it effective for extinguishing various types of fires. However, caution is advised, and it is not recommended to be in close proximity to the substance.
DaveC426913
I just saw an article on TV about this new material by 3M called Novec 1230 (or Sapphire by Ansul) that looks and acts much like water, but isn't.
It's non-conducting and non-destructive. I was wondering what this material would be like to handle. I wondered how hard it would be to tell that it was not water, by, say, weight, vicosity or other.
But they mention that it evaporates about 25x faster than water. It seems to me, that it would appear and behave very much like alcohol - it would be cold to the touch and would noticeably evaporate like alcohol does.
I wonder if it is aromatically volatile like alcohol (though they seem to have no problem with large, open containers of the stuff.)
Computer science news on Phys.org
http://tsp-europe.com/English/Products/Extinguishing/novec1230.asp
I should have added that I have been looking around a bit, but I haven't found anything that talks about what it's like to handle or touch.
Normal boiling point is 49 C --- that give you any hints? Be about like chloroform. Plus, it might be absorbed fairly rapidly through the skin --- plus, the health and safety hazards are downplayed for marketing purposes --- plus, you throw any fluorinated organic compound into a fire you get HF. Does it burn if mixed with air? No. Does it evaporate and carry off a lot of combustion heat? Yes. Enough to quench enough different fire types to make it useful? Yes. Do you want to be in the room with it? No.
Sorry if 'Profile Badge' is not the correct term. I have an MS 365 subscription and I've noticed on my Word documents the small circle with my initials in it is sometimes different in colour document to document (it's the circle at the top right of the doc, that, when you hover over it it tells you you're signed in; if you click on it you get a bit more info). Last night I had four docs with a red circle, one with blue. When I closed the blue and opened it again it was red. Today I have 3...
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
