The Duration of the Big Bang: Exploding Myths and Misconceptions
  • Thread starter Brunolem33
  • Tags
    Big bang
In summary: But exactly what remains a mystery. On the other hand, if the Big Bang was, or is, a "continuing event", the energy could have been released incrementally.Yes, this is definitely possible. The Big Bang was a release of energy, lots of it.This is true if by "Big Bang" you mean what happened at the end of the inflation era, when the matter and energy in our current universe was first formed in a very hot, very dense, rapidly expanding state. But this event is not an "initial singularity" despite what many pop science presentations say. See below.
  • #36
phinds said:
Those happen at a point. The BB singularity did not.
Hi phinds:
If the universe is finite, then its volume is and always has been finite. If we ignore the Planck period as special with respect to the GR gravitational model, the scale factor, a, approaches zero as time approaches zero. The volume of a finite universe is always proportional to a3. Therefore the volume approaches zero as time approaches zero. Linguistically, it seems reasonable to say that a volume that approaches zero approaches a spacially geometric point.
Your statement that the BB did not happen at a point seems reasonable only from a point of view that explicitly leaves time equals zero out of the discussion. But if the discussion includes a singularity, then for a finite universe it seems reasonable to say the singularity occurred at time equal to zero, and for a finite universe the volume at that moment is zero. Therefore it is reasonable to say the singularity was a point singularity. I think it is also reasonable to say that this singularity happened at a point in 3+1D spacetime.
Regards,
Buzz
Space news on Phys.org
  • #37
And it is correct to leave time = zero out of the discussion, because that time--the initial singularity--is not part of spacetime. Pop science presentations often fail to mention this, because it takes a lot of the fun out of talking about the initial singularity. In the actual models (the FRW spacetimes, and in fact spacetimes in general), singularities are not part of the manifold.
Also, the term "Big Bang" as it is standardly used in cosmology, does not refer to the initial singularity; it refers to the hot, dense, rapidly expanding state that was present at the end of the inflationary era. That is the earliest point at which our knowledge is reasonably reliable. We certainly do not know enough to say that that hot, dense, rapidly expanding state arose from an earlier state that approached infinite density. In fact, most cosmologists do not believe that is the case.
  • #38
Hi Peter:
I thought that the inflationary period was not "officially" part of the standard model, but remains a still controversial proposal for a possible extension of the model. If the inflationary period is excluded, what other event becomes the beginning of "the hot, dense, rapidly expanding state" of the universe? Could it be the end of the Planck era?
If the inflationary period is included in the model, then the time at which the BB happened is definitely not t=0.
Regards,
Buzz
  • #39
Buzz Bloom said:
Hi phinds:
Regards,
Buzz
I disagree w/ your conclusion. The problem here is that you are taking the limit seriously and as Peter said, that makes no sense. Yes, the universe gets smaller and smaller as you approach zero but since you can't take the zero part seriously, you have to stop somewhere and wherever you stop there is a current universe size that corresponds to that initial size and that initial size can be any arbitrary size since there is always a current size that corresponds to it. If we knew the size of the current universe we could extrapolate all the way back to one Plank Time and say what it was then, but it would not be zero and could well but enormous.
If infinite now then it was infinite then but I get that you already realize that.
  • #40
The inflationary period itself is still a matter of investigation, because we don't know exactly which inflationary model is the right one. But the "BIg Bang" state at the very end of inflation is part of the standard model, and the fact that that state was produced by "reheating" when inflation ended is also, AFAIK, part of the standard model.
The hot, dense, rapidly expanding state itself is the "beginning". Even if, for some reason, we discovered that none of the inflationary models would work, that wouldn't change the fact that the hot, dense, rapidly expanding state existed, and that it can serve as the starting point for our model of the universe since that state. I referred to it as happening at "the end of inflation" because, as I said above, the end of inflation is part of the standard model of cosmology, even if the details of how inflation happened are not because we don't know for sure which model is right.
No. The hot, dense state we know to have existed, and which we call the Big Bang, was still many orders of magnitude less hot and dense that an end of Planck era state would be.
It's not even if, for some reason, we discovered that no inflationary model would work. The time at which the BB happened is the time at which the BB happened--the time at which the hot, dense state we call the "Big Bang" happened. That time is not "t = 0" (i.e., the notional time coordinate assigned to the "initial singularity") in any cosmological model.
Likes Buzz Bloom
  • #41
Hi Peter:
Thanks for your post. I much appreciate all your answers to my questions.
Is it possible to associate the event you have identified as
with any particular event other than the end of inflation? I am thinking of such candidate events as the following.
(1) The first creation of the Higgs boson
(2) The weak-EM symmetry breaking
(3) The GUT symmetry breaking
(4) The electron positron annihilation
(5) The quark anti-quark annihilation
(6) Other?
Regards,
Buzz
  • #42
Hi phinds:
I am not sure which of my conclusions you disagreed with. I think you may have misundefrstood my point.
In these statements I was not talking about physics. I was talking about discussions. I get that the singularity is not part of the physics. However, a discussion about where or when the singularity occurred is then not physics. It's just about the math. When discussing math it is OK to say that
f(x) = 1/x has a singularity at x=0.​
Regards,
Buzz
  • #43
Buzz Bloom said:
Hi phinds:
Regards,
Buzz
Sorry, I thought we were discussing physics. If you want to discuss unicorns, that's perfectly reasonable, just not something I have any interest in.
  • #44
All of these events happened after the Big Bang--that is, they happened after the hot, dense state was already formed. They are all particular things that happen at various temperatures as the hot, dense state expands and cools.
  • #45
Hi Peter:
Thanks for your post. Your answer helps clarify my confusion, but raises another question.
Earlier I asked, "Could it be the end of the Planck era?" where "it" refers to the beginning of "the hot, dense state". You answered:
Why was the much hotter temperature at the end of the Planck era state incompatible with the Big Bang hot, dense state? In what way would the higher temperature at the end of the Planck era interfere with some defining attribute of the Big Bang state?
Regards,
Buzz
  • #46
He never said it was incompatible. He said we cannot extrapolate our theories to the Planck era and be certain that they will be valid. This is simply because we have not made observations at the energies required to tell what goes on in such extreme situations.
  • #47
Hi Orodruin:
Thanks for your post. I confess I had misinterpreted what Peter meant.
Regards,
Buzz
  • #48
Hi Peter:
The quote above answered my question about 5 candidate events. I have found in the Wikipedia article
some "dates" that seem inconsistent with this answer, and
(1) The "Inflationary epoch" had an "unknown duration", but ended "10−32(?) second after the Big Bang."
(2) The "Grand Unification" epoch occurred "between 10−43 second and 10−36 second after the Big Bang."
(3) The "Electroweak epoch" occurred "between 10−36 second (or the end of inflation) and 10−32 second after the Big Bang."​
If I am interpreting this correctly, the Grand Unification epoch and the Electroweak epoch occurred before the BB. Please comment on this.
Regards,
Buzz
  • #49
https://en.wikipedia.org/wiki/Chronology_of_the_universesome "dates" that seem inconsistent with this answer
These times are based on a non-inflationary cosmology. Note this statement: "In inflationary cosmology, times before the end of inflation (roughly ##10^{−32}## second after the Big Bang) do not follow the traditional big bang timeline." In other words, the numbers you are seeing for the Grand Unification and Electroweak epoch are not valid in inflationary cosmology.
Nor, in fact, is the number ##10^{-32}## seconds for when the inflationary epoch ended really valid; it's just a notional number which is itself based on what the time "would have been" in a non-inflationary model. That estimate, in turn, is based on an estimate of what the temperature and density was of the hot, dense state that was formed by reheating at the end of inflation--that temperature and density is then plugged into a non-inflationary model, which pops out a notional "time after the initial singularity" when the universe would have had that temperature and density. In other words, all of these numbers are just notional labels and don't really mean anything physically.
Also, note that this whole article uses the term "Big Bang" to refer to the initial singularity, not to the hot, dense state at the end of inflation. This, as I have explained, is not really correct terminology, but what can you expect from Wikipedia?
  • #50
Hi Peter:
Thank you for your prompt and useful answer. I think I now understand that the Wikipedia time line is based on assuming inflation never happened, except for the rather strange vague time given for inflation based on trying to be consistent with the other dates.
One thing I remember reading about inflation was that it's ending caused the first creation of matter of the kind described in the standard model. (I am unable to track down right now where I read this.) Does this seem correct to you?
I also remember reading in another thread a discussion about the existence of magnetic monopoles before inflation, and the thinning out of these primordial particles during inflation so that they can no longer be found in the observable universe.
Can you recommend any useful references that discusses (1) the time line based as assuming inflation did happen, and/or (2) attributes of the stuff in the universe before inflation?
Regards,
Buzz
  • #51
Lol... looks like Buzz said about the same thing, back on September 5, 2015...
Maybe... here ?
Good discussion... carry on.
Likes Buzz Bloom
  • #52
Yes, this is what "reheating" is in inflationary models: the energy stored in the inflaton field gets converted into ordinary matter and radiation--standard model particles.
AFAIK magnetic monopoles are still only speculative. They are predicted by most Grand Unified Theories, but there is no evidence for them that I'm aware of.
Unfortunately, all the non-technical references I'm aware of use the same "notional" times that the Wikipedia article you quoted uses. Part of the problem may be that inflationary models don't really tell us anything about "how long" things took in any meaningful sense. More technical references don't talk about time at all; they talk about the number of doublings of the size of the universe that would have been required for our current observations to be consistent with the model. (Usually that number, IIRC, is somewhere around 60 doublings.)
As far as the attributes of the stuff in the universe before inflation, I don't think there is any real answer at this point. During inflation, the only "stuff" in our observable universe would have been the inflaton field itself (the field that drives inflation). The question is what the inflaton field came from, and AFAIK answers vary greatly between inflationary models.
Likes Buzz Bloom
  • #53
Hi Peter:
Thanks again for your prompt and informative answers.
Regards,
Buzz
  • #54
phinds said:
The big bang singularity happened everywhere at once
Can anyone tell me the mechanism for this? Or does it defy known physics and logic?
  • #55
"Singularity" is a placeholder word for the phrase "we don't know what the ... was going on or how it happened", it's just a non-physical answer that falls out of the math. (but we know a lot about what happened starting about 1 Plank Time after it happened)
  • #56
This questions is equivalent to saying 'what caused the big bang?', and there is no shortage of ideas, but no particular one is more convincing, (to me anyway).
However the mechanism (cause of) it is not part of the big bang theory itself.
It doesn't defy physics and logic since it's based on observational evidence.
The theory makes complete sense from a moment (1 plank time) after the actual big bang leading to the subsequent evolution of the Universe we see today.
However before this time we have one of those dreaded singularities - and yes that does defy logic.
All it really means though is that we don't know what happened, and the most likely explanation is that there is physics going on which we so far don't understand.
There are ways of getting rid of the singularity, (aka mathematical nonsense) by introducing ideas such as a cyclic Universe (different versions of this), but as far as I know these kind of models also run into mathematical conundrums, just they are ones of a different kind.
  • #57
We don't have observational evidence for 1 Planck time after a postulated "initial singularity". We only have observational evidence for the hot, dense, rapidly expanding state at the end of inflation, and for some of the characteristics of the inflation era before that. In inflationary models, there is no "initial singularity".
  • #58
rootone said:
This questions is equivalent to saying 'what caused the big bang?', and there is no shortage of ideas, but no particular one is more convincing, (to me anyway)...
Thanks Rootone, but I wasn't referring to the "Big Bang" but rather the idea that it happened everywhere at once. How do we know it happened everywhere at once?
  • #59
Because we see the remnants of it to be the same everywhere at once. The most obvious remnant is the CMB, which is the same in all directions to one part in 100,000. If the process that led to the CMB didn't happen everywhere at once, it would look different in different directions (for one thing, it would have a different redshift in different directions).
Of course, the CMB was produced a few hundred thousand years after the Big Bang; but we can apply the same reasoning to observations that come from much earlier. For example, the relative abundances of light elements, which are the result of nucleosynthesis in the first few minutes after the Big Bang, are the same everywhere, as far as we can tell. If the Big Bang had happened at different times in different parts of the universe, that would not be the case.
  • #60
Ok. That is convincing.
Hold it. Then I am not seeing how it is a remnant of the Big Bang. From what I understand the B.B. produced a universe that was huge in less than a second. After one year it was "several times huge" and I would expect 100,000 years would provide time for some sort of changes to begin. So the CMB could be due to something else maybe? For example, my source says:
"The cosmic microwave background (CMB) is the thermal radiation left over from the time of recombination in Big Bang cosmology. In cosmology, recombination refers to the epoch at which charged electrons and protons first became bound to form electrically neutral hydrogen atoms. Recombination occurred about 378,000 years after the Big Bang (at a redshift of z = 1100).”
“Immediately after the Big Bang, the universe was a hot, dense plasma of photons, electrons, and protons. This plasma was effectively opaque to electromagnetic radiation due to Thomson scattering by free electrons, as the mean free path each photon could travel before encountering an electron was very short. As the universe expanded, it also cooled. Eventually, the universe cooled to the point that the formation of neutral hydrogen was energetically favored, and the fraction of free electrons and protons as compared to neutral hydrogen decreased to a few parts in 10,000.
“Shortly after, photons decoupled from matter in the universe, which leads to recombination sometimes being called photon decoupling, although recombination and photon decoupling are distinct events. Once photons decoupled from matter, they traveled freely through the universe without interacting with matter, and constitute what we observe today as cosmic microwave background radiation.”
So it sounds to me that some believe the CMB was created by recombination and that recombination occurred as much as 378,000 years after the B.B.
That would mean that the cause of the CMB was already distributed in every direction and so it would not be subject to red shift resulting from the expansion of the B.B. itself.
What am I missing?
Ok, I'm going to have to give up on this and just draw my own conclusions I guess, because according to everything I ever learned AND according to the quotes I posted in the above paragraphs all there was for long after the B.B. was electrons, protons, and photons forming a hot plasma, and the "light elements" to which you refer didn't exist "in the first few minutes after the Big Bang". It took hundreds of thousands of years for the first, simplest element, -hydrogen, -to form.
Thanks.
  • #61
Huh ?
  • #62
It's a remnant of the process that started with the Big Bang, and it gives us information about that process, including how it started. See further comments below.
Define "huge". Usually the various phases of the process are described in terms of the density or temperature, not the "size of the universe" (which is something of a misnomer in any case, since according to our current best model the universe is spatially infinite).
This isn't something that "some believe"; it's part of the standard model of cosmology. But, as I said above, recombination is part of the process that started with the Big Bang, and the CMB, by giving us information about recombination--when it happened and how evenly it happened everywhere in the universe--gives us information about the process that led to it. Once again: if the Big Bang had happened at different times in different parts of the universe, then recombination would have happened at different times in different parts of the universe, and the CMB would not have the same redshift and other characteristics in all directions.
I don't understand what you mean by this.
No, it took hundreds of thousands of years for atoms of hydrogen to form--in other words, for the universe to become cool enough that, when electrons combined with nuclei to form atoms, the atoms didn't immediately get blasted apart again by radiation. But hydrogen nuclei were formed in the first few minutes after the Big Bang, along with the nuclei of a few other light elements. (Protons, btw, are hydrogen-1 nuclei; but nuclei of hydrogen-2/deuterium, helium-3, helium-4, and lithium-7 were also formed in the first few minutes.)
  • #63
OCR said:
Huh ?
I'm responding to Dave Eagan's question, "how do we know the Big Bang happened everywhere at once?" In order to respond to that, I have to consider the possibility that it didn't, and show how that would lead to predictions that are contrary to our observations.
  • #64
Let's review my original question. I asked how we know that the B.B. "happened everywhere at once", and the answer given was that the CMB is uniform in all directions with no red shift.
Before that, however (if I have it right), nucleosynthesis, which happened just minutes after the B.B., created atomic nuclei (protons). About 378,000 years later those nuclei became bound to electrons, forming hydrogen atoms.
You also said that recombination is part of the process that started with the Big Bang. Ummm, well, of course it is, as is everything else. So I don't find that adding to my understanding yet.
I assume that since such processes as electrons changing their position around nuclei and bonding with protons to form atoms involves a release of energy, that it may be this bonding that produced the CMB. Could it be that I'm right?
If the CMB originated almost 400,000 years after the B.B. and it originated when electrons became bound to protons to form hydrogen atoms, by then the universe had expanded how many lightyears? I don't have that info handy but the number was significant, and so at that point the generation of radiation from the event of electrons bonding to protons would have happened "everywhere at once" it would seem since the universe was already so large. Plus, radiation generated by one electron bonding to one proton would be an event in a point in space in an instant of time. Hence there would be no red shift since the source is not continually emitting radiation as it moves.
Realize that I came here to get answers from people who know this stuff much better than I do, and the best way I can find to get you to understand my question (since I'm not up to speed on correct terminology) is to express what I can imagine to be "reasonable explanations" so that you can correct my errors and assumptions. This would, I hope, help you to avoid answering a question I didn't ask due to a misunderstanding of where my confusion lies.
Thanks.
  • #65
To address a few of your points:
Dave Eagan said:
... then the universe had expanded how many lightyears?
This is not a meaningful question. The universe does not expand by lightyears, it expands at a rate. Things move apart and if you can identify two objects, then it is valid to ask how many lightyears apart they have moved.
... it would seem since the universe was already so large.
Size is not necessarily meaningful since it may have been infinite to start and thus infinite at every point in time since then.
This is a misunderstanding. Of course there would be red shift. Ref shift due to cosmological expansion has nothing to do with the movement of the source after a photon is emitted, it has to do with the fact that the space through which the photon travels is expanding.
  • #66
Well, I'm reading elsewhere and finding that I'm getting more confused. It seems what I'm reading contradicts itself and the explanations aren't chronologically sequenced.
This doesn’t make sense to me... http://cosmictimes.gsfc.nasa.gov/online_edition/1993Cosmic/inflation.html
“Inflation Theory explains . . . that shortly after the Big Bang, the universe expanded tremendously in a very short amount of time. This expansion grew the size of the universe from submicroscopic to the size of a golf ball in 10-35 seconds. Thus, regions once in contact with each other are now far apart in the universe.”
An inch and a half? But wait! There's more ...
“As space expanded, the universe cooled and matter formed, and then protons and neutrons formed.”
Pardon me, but matter is protons and neutrons . . . and electrons, etc. So what’s this “and then” business? Cart before the horse?
Once again, the source of the CMB is recombination? In layman's terms, the CMB is the energy released when atoms are formed from free charged protons and electrons? If so, the energy released from one such event would be identical to the energy released from every such event. So I'm having trouble being excited or surprised by the fact that the CMB is uniform.
  • #67
"Ref shift due to cosmological expansion has nothing to do with the movement of the source after a photon is emitted, it has to do with the fact that the space through which the photon travels is expanding."
And yet red shift is an effect of movement of an object away from the observer.
  • #68
To address just one of your questions:
Dave Eagan said:
An inch and a half?
Yes. That's the observable universe. You need to familiarize yourself with
o the term "universe"
o the term "observable universe"
o the fact that many people say "universe" when they mean "observable universe", which leads to confusion
  • #69
Only in the sense that recession is a form of objects moving away from each other, but this is not proper motion. You need to study the difference between recession and proper motion. Google "metric expansion"
  • #70
Gotcha... carry on. :oldcool:
  • Cosmology
