Dynamic Link Library, Compaq Visual Fortran 6.6 & Module
The discussion revolves around the creation and use of dynamic-link libraries (DLLs) in Fortran applications using Compaq Visual Fortran 6.6. Participants explore issues related to variable scope and initialization when using modules in DLLs compared to traditional subroutines.
  • One participant shares a working example of a DLL subroutine that correctly computes a sum, while another example using a module yields an incorrect result of zero.
  • Another participant suggests that the module may only declare local variables and proposes using COMMON blocks to make variables global.
  • Some participants reference external sources claiming that modules have global characteristics, questioning the inconsistency observed in the results.
  • A participant notes that the same algorithm without using the DLL works correctly, indicating that the issue may be specific to the DLL implementation.
  • Concerns are raised about different address spaces being assigned in the DLL and the main executable, which could lead to the observed discrepancies.
Participants express differing views on the behavior of modules in DLLs, with some suggesting a need for global variable handling while others reference external sources that claim global characteristics. The discussion remains unresolved regarding the underlying cause of the incorrect results.
There are limitations regarding the assumptions about variable scope and initialization in the context of DLLs and modules. The discussion does not resolve the mathematical or technical steps involved in the implementation.
Bakhbergen
Dear Forum Members,
I need to create and use dynamic-link library (DLL) for Fortran application using Compaq Visual Fortran 6.6. The following code works just fine:
PROGRAM AMAIN1
IMPLICIT NONE
REAL(8):: A,B,S
A = 1D0
B = 2D0
CALL SUBRO1(A,B,S)
PRINT*, 'S = ', S
END PROGRAM AMAIN1
SUBROUTINE SUBRO1(A,B,S)
!DEC$ ATTRIBUTES DLLEXPORT :: SUBRO1
IMPLICIT NONE
REAL(8):: A,B,S
S = A + B
RETURN
END SUBROUTINE SUBRO1
The result is correct:
S = 3.00000000000000
Press any key to continue
However, if I implement the same algorithm using the module, I get inconsistent result (i.e. zero):
PROGRAM AMAIN2
USE MODUL2
IMPLICIT NONE
A = 1D0
B = 2D0
CALL SUBRO2
PRINT*, 'S = ', S
END PROGRAM AMAIN2
MODULE MODUL2
IMPLICIT NONE
REAL(8):: A,B,S
END MODULE MODUL2
SUBROUTINE SUBRO2
!DEC$ ATTRIBUTES DLLEXPORT :: SUBRO2
USE MODUL2
IMPLICIT NONE
S = A + B
RETURN
END SUBROUTINE SUBRO2
The result is incorrect:
S = 0.000000000000000E+000
As can be seen above, DLL contains only subprogram in both cases (SUBRO1 and SUBRO2, respectively). I have built DLL and LIB files from the visual development environment. The second case (with the use of module) represents the structure of my large source-code so I need to resolve this issue. Any advice would be greatly appreciated.
Hallo Bakhbergen, ##\qquad## :welcome:
Modul2 is only a declaration of local variables. You need something like COMMON to make them global is what I would suspect.
(old hand, more fortran 77 than f90, but who knows this helps)
BvU said:
However, https://www.tutorialspoint.com/fortran/fortran_modules.htm claims global character.
Your result does not reflect that. Still worth investigating (ask for the addresses of the variables in debug or something ?)
Hello BvU! I appreciate your intention to help with this. There weren't any error / warning during the debugging. Just gives incorrect result.
I don't expect any errors reported, just diffferent address spaces assigned in the DLL and the main EXE
BTW, the same algorithm without using the DLL works well and gives correct result:
PROGRAM AMAIN3
USE MODUL3
IMPLICIT NONE
A = 1D0
B = 2D0
CALL SUBRO3
PRINT*, 'S = ', S
END PROGRAM AMAIN3
MODULE MODUL3
IMPLICIT NONE
REAL(8):: A,B,S
END MODULE MODUL3
SUBROUTINE SUBRO3
USE MODUL3
IMPLICIT NONE
S = A + B
RETURN
END SUBROUTINE SUBRO3
