Dynamical systems and thermodynamics
The discussion focuses on the mathematical representation of dissipative dynamical systems in relation to thermodynamic laws. Participants seek references and resources that detail how these systems can demonstrate compliance with thermodynamic principles. A specific example is provided, illustrating the relationship between stress and time or strain, using stress (σ), time (t), strain (ε), and constants (kt and kε). The conversation emphasizes the need for detailed and specific mathematical formulations. Overall, the thread highlights the intersection of dynamical systems theory and thermodynamics, seeking clarity on their relationship.
JRR
Is there a mathematical way to show that a dissipative (or general?) dynamical system obeys the laws of thermodynamics?
I am looking for books/sites/references, thanks for any reply.
Science news on Phys.org
Thanks for your reply.
The system would typically be the development of stress versus time, or alternatively stress versus strain for a given strain rate.
The simplest form I could think of is this (two variants, as described above):
Where σ is the stress, t is time, ε is strain and kt and kε are constants.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
