E-Field in a Ring: Homework Solutions
  • Thread starter Thread starter yinx
    E-field Ring
The E-field at the center of a uniformly charged metal ring is zero due to symmetry, as the electric fields from opposite sides cancel each other out. For points within the circumference of the ring, the E-field is not zero; it varies in magnitude and direction since the contributions from opposite points do not balance out. The confusion arises from the assumption that the E-fields at these points would cancel completely, which they do not. Understanding the vector nature of electric fields is crucial for analyzing points off-center. Clarification on these concepts can enhance comprehension of electric field behavior in symmetrical charge distributions.
yinx
a) What is the E-field at the center of a metal ring which has uniform charge density?
b) Is E=0 for any other point within the circumference of the ring?2. The attempt at a solution
For (a), since the ring has uniform charge density and is symmetrical, based on symmetry, E-field from opposite sides "cancels" each other out therefore the E field at the center of the ring should be E=0. Am I correct?
For (b), this is the one that got me confused. I was thinking that E-field at all other points (other than the center) should be non-zero as the E-fields from opposite ends at these points are opposite in direction however not equal in magnitude. However I am not too sure about this.
Greatly appreciate if anyone can enlighten me.
-yinx-
anyone?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
