E1 vs E2 Mechanisms: Understanding Catalysts
  • Thread starter MathewsMD
In summary, the difference between E1 and E2 mechanisms lies in the acidity of the alpha proton and the leaving group. In E1, the leaving group is abstracted first, creating a highly electron-withdrawing carbocation which makes the alpha proton extremely acidic. This allows for a weaker base, such as water, to remove the remaining proton and proceed with the reaction. On the other hand, in E2, the alpha proton is not very acidic and thus requires a stronger base, like OEt-, to abstract it and cause the leaving group to leave in a concerted manner. This difference in acidity also explains why OEt- cannot be used as a catalyst for the E1 mechanism, as it would simply deprotonate the proton
MathewsMD
433
Hi,
I'm just reviewing E1 and E2 mechanisms and I had one question regarding the catalysts. I've attached the image for the 2 reactions I have a question about.
I understand E1 mechanisms are more common for reactions with tertiary carbocation intermediates while E2 is more common for primary, and that E1 or E2 would occur for secondary (though it would depend on the intermediate stabilities, correct?). In the image posted, there are 2 reactions (E1 and E2) with the same original reagent. I just don't quite understand why OEt-, the catalyst for the E2 mechanism, cannot be used for the E1 mechanism (i.e. why is water used as opposed to OEt-?). They both seem to be LB, though OEt- stronger, and I would presume OEt- can be used as a catalyst for the E1 mechanism, but it appears not. Is there any particular reason why using OEt- (or any other molecule like OCH3-) does not lead to the E1 mechanism but instead to E2 only? Does it have to do with water being a smaller molecule and allowing the reaction to not be stereoselective? Why cannot the stronger LB like OEt- lead to the E1 mechanism?
Likes Apleo
Chemistry news on Phys.org
Take a look at your final (not alkene) products: for E2, you get neutral ethanol, whereas for E1, you get H3O+, a charged species. The answer to your question has to do with the acidity of the alpha proton (the hydrogen on the carbon next to the leaving group). In an E2 reaction, a Lewis base abstracts the alpha proton and the leaving group leaves in a concerted manner ("concerted" just means "at the same time"). Since the alpha proton isn't particularly acidic in this case, you need a pretty strong base to pull it off. In the case of an E1 mechanism, though, the leaving group is abstracted first, and what you're left with is a hydrogen which is alpha to a carbocation. In this case, the carbocation is highly electron withdrawing (as a result of its being positively charged), and the alpha proton becomes extremely acidic. Therefore, the base you need to pull off the remaining proton doesn't have to be nearly as strong (in this case, H2O is a much weaker base than OEt-).
Yes. Thank you. Just to clarify: the base you need to pull of the remaining proton therefore doesn't have to be nearly as strong, but can't it still be strong and still allow the mechanism to proceed? Why can't EtO- be used for both reactions? (i.e. for the E2 mechanism, it uses only EtO- and has only one product, but why can't both products, like formed in the E1 pathway, be made if you already have a strong enough base?)
Likes Apleo
You can use a stronger base. You just don't have to. But I have to caution you that this isn't always true. Think about acid-catalyzed dehydration proceeding through an E1 mechanism. In this case, the first step is to protonate a hydroxyl to -OH2+, which then eliminates as water, at which point a weak base (usually water in this case) can remove the remaining alpha proton. If you try to use a strong base in a reaction like this, you'll just end up deprotonating the protonated hydroxyl -OH2+, turning it back into an -OH group. In this case, the use of a strong base won't push the reaction forward.
Hi there,
Thank you for your question about E1 and E2 mechanisms and their respective catalysts. You are correct in your understanding that E1 mechanisms are more common for reactions with tertiary carbocation intermediates, while E2 is more common for primary. And yes, for secondary carbocation intermediates, the mechanism that occurs would depend on the stability of the intermediate.
In regards to your question about why OEt- cannot be used as a catalyst for the E1 mechanism, the answer lies in the nature of the E1 mechanism itself. E1 mechanisms involve a two-step process, where the first step is the formation of a carbocation intermediate and the second step is the removal of a leaving group. In this case, the leaving group is water, which is a weaker base than OEt-. This means that water is more easily removed in the second step, allowing for the formation of the final product.
On the other hand, in the E2 mechanism, the reaction occurs in one step where the leaving group is removed by a strong base, such as OEt-. This strong base is able to remove the leaving group and also act as a nucleophile, resulting in the formation of the final product.
In summary, the reason why OEt- cannot be used as a catalyst for the E1 mechanism is due to the difference in the strength of the leaving group and the base, which is essential for the two-step process of the E1 mechanism. The use of OEt- would result in a different mechanism, such as E2, due to its strong basic properties. I hope this helps clarify your question. Please let me know if you have any further inquiries.
1. What is the difference between E1 and E2 mechanisms?
E1 and E2 mechanisms are two different pathways for a reaction to occur. E1 reactions involve a two-step process where the leaving group leaves first, creating a carbocation intermediate, followed by the elimination of a proton to form the final product. E2 reactions, on the other hand, occur in a single step where the leaving group and a proton are eliminated simultaneously.
2. How do catalysts affect E1 and E2 reactions?
Catalysts can speed up both E1 and E2 reactions by providing an alternative pathway with lower activation energy. They do this by stabilizing the transition state, making it easier for the reaction to occur. However, the type of catalyst used may have a different effect on the rate of each mechanism.
3. What factors influence the selectivity of E1 vs E2 reactions?
The selectivity of E1 and E2 reactions is influenced by several factors such as the strength of the base, the structure of the substrate, and the solvent used. Generally, E1 reactions are favored when the base is weak and the substrate is bulky, while E2 reactions are favored when the base is strong and the substrate is less bulky.
4. Can E1 and E2 reactions occur at the same time?
Yes, it is possible for E1 and E2 reactions to occur simultaneously. This is known as a competing reaction, where both mechanisms are competing for the same reactant. The product distribution of these reactions will depend on the relative rates of each mechanism and the conditions of the reaction.
5. How do we determine which mechanism is favored in a reaction?
The mechanism that is favored in a reaction depends on several factors such as the substrate, the base, and the solvent used. One way to determine which mechanism is favored is by performing experiments under different conditions and analyzing the product distribution. Additionally, computational methods can also be used to predict the most favorable mechanism for a given reaction.
10K
  • Science and Math Textbooks
