How Long Until Earth Collides with the Sun if its Orbit Stops?
  • Thread starter Thread starter Benzoate
    Earth Sun
Benzoate
If the Earth were suddenly stopped in its orbit, how long would it take for it to collide with the sun?(Regard the sun as a fixed point mass. You may make use of the formula for the period of the Earth's orbit.
tau=(4*pi^2*R^3/M*G)^.5
Should I considered the velocity of the Earth before it came to a halt in its orbit? ; the radius between the two bodies are obviously not fixed. What do they mean when they say regard the sun as a fixed point mass?
It says the Earth stopped, so no.
It means just assume all the suns mass is at the centre, you don't have to worry about the mass near the edges of the sun pulling the Earth at a slightly different angle.
It 'probably' also means you work out the time for the centres to collide, not the time for the edge of the Earth to reach the outer edge of the sun.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
