Are power stations wasting energy during Earth Hour?
  • Thread starter Thread starter chebyshevF
    Earth Power
The Earth Hour movement encourages people to turn off electrical appliances for an hour to conserve energy. When many users disconnect from the grid, power stations continue generating electricity, which can lead to wasted energy if demand drops significantly. Power stations adjust their output based on real-time demand feedback, using automatic sensors to maintain generator speed and frequency. While conventional power plants can reduce fuel consumption with lower loads, nuclear power stations face challenges as they take longer to shut down and cannot quickly adjust their output. Overall, the efficiency of power generation during Earth Hour depends on the type of power station and its ability to respond to sudden changes in demand.
chebyshevF
Has everyone heard about the Earth Hour movement? Where you're encouraged to turn off anything that uses electricity in your home, for an hour, to conserve energy.
What I'm wonedering is: let's say that a large group of people depend on a specific power station, so when they all, or the majority, turn off all electrical appliances, what happens with the power that is generated at the power station? I'm guessing they still continue to generate electricity, and isn't it true that this power cannot be stored, so would it be right to say that the power stations are generating electricity that is just being wasted? Since for that whole hour, there wouldn't be as much of a demand, therefore the power station is pointlessly generating electricity that nobody is using for the time being?
I'm not sure if I make sense, but basically: is the power that is generated at the power station, being wasted owing to the fact that it isn't being used during the hour period?
The generators at the power station become easier to turn if the load is reduced.
So, the power plant which turns the generators uses less fuel to rotate the generators at the right speed.
No unwanted power is produced and less fuel is used.
As long as the power station keeps producing the right voltage, the current drawn just depends on which appliances are switched on or off.
So the rate at which the generators are being turned depends on how high the demand is at the load?
But how does the power station know when the demand is high or low? Wouldn't it take some amount of time for the power station to be given some form of feed back by the load, that more power is needed, therefore they need fuel?
The speed of the generator rotation determines the frequency of the output. This may be 50 or 60 Hz but it must remain constant regardless of load.
If this starts to decrease, automatic sensors detect the difference and apply slightly more accellerator pressure to bring the speed back to normal again.
If everyone in a whole city turned off the power at once, the power station might have a few seconds of rapid adjustment while the power from the power plant was reduced.
These are very large heavy machines, so minor changes in current drain have little effect on the speed of their rotation.
The current drawn is also measured from second to second and the mechanical power input is adjusted automatically to maintain constant RPM from the generators.
So if you have a generator with practically zero load and another one at near max load, both turning at the same RPM, then the one with zero load will use less fuel?
Yes. It's like a couple riding a tandem. The one at the back can just pedal lightly and the guy in front would just think the hill was steeper than it looked.
Nuclear Power Stations are more of a problem because (see recent news) they take a long time to shut down completely so they produce no steam.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
