Easy algebra - Calculus question help - find roots of
In summary, In incorrect equations 1 and 2, cosine and sine are out of phase by pi/2. In incorrect equation 3, 1/(x-3)=-a/(x(x-3)) for x=-3.
vorcil
398
1: Which of the following is incorrect
a cos2x = 2-(sin^2) x
b (sin^2)x + (cos^2)x = 1
c cos x = sin ( pi/2 -x)
d sin2x = 2sinxcosx
I know b is correct, fairly sure c is correct because i know cos is out of phase by pi/2
have no bloody idea how to determine which of these is wrong
help please, need to know the rules/trig identities
2:
if a = 3/4, then 1/ a+1 = 1/1.75
HOWEVER i need to know how to do this, without a calculator, we are allowed NO calculator during the exam, and the awnser is something like 0.57632
3: 1/x - 1/(x-3) = a / x(x-3)
solve for a,
i tried multiplying the first side by x-3, so got (x-3)/(x(x-3)) - (x-3)/(x-3)
(x-3)/(x^2-3x) - 1 = a / (x^2 -3x)
moving (x^2-3x),
(x-3) -1 = a
x -4 =a?
help pl0xzafd
d sin2x = 2sinxcosx
The easiest way to find the incorrect equations is to pick values at which cosine and sine are easy to evaluate. For example, let x=pi or x=0, and see which equations fail to be true.
vorcil said:
2:
If a=3/4, then
[tex]
\frac{1}{a+1} = \frac{1}{3/4+1} = \frac{1}{3/4 + 4/4} = \frac{1}{7/4} = \frac{4}{7}
[/tex]
Remember that dividing by a fraction is the same as multiplying by its reciprocal. Can you divide 7 into 4 to get the first few digits of 0.57632?
Let's hold off on #3 until we get these.
If a=3/4, then
[tex]
[/tex]
Sweet, i get number two, i didn't think of turning 1 into 4/4 XD
as for the first question, I am not allowed to use a calculator at all during the test, so can't really substitute in complex cos/sine stuff (i know simple ones like cos 90= 0 ect..ect..) but nothing to hardcore
While you definitely should verify each trigonometric equation, what happens with the first one is at x=0? A nice tip for stuff like this is thinking of the magnitude of sine and cosine. Sin^2, Sin^3, Sine to any power along with Cosine to any power or with any argument (like 2x, 3x, 4x, 10414x) have a maximum magnitude of 1. If you multiply them together (such as Sin(3x)Cos(2x) ), however, this argument doesn't hold.
Turning 1 into 4/4 is the same process as finding a common denominator. Also, I meant try x=pi/2, not pi. Sorry. And pi/2 is 90 degrees in radians. So what happens when you substitute in x=0 or x=90? If an equation gives something that isn't true, like 0=1 or something else, then the equation is incorrect. If it gives something correct, then it is likely to be a correct equation (but not always though!), so you need to just have the trigonometric equations memorized before a test.
yeah i just looked up the trigonometric identities on google, and I'm memorizing them all
i know most of them, but some i missed out! must've been talking during class at high school lol.
turns out, well at least i think, question 1, a is wrong
How do i find the roots of x in the equation
2x^2 -5x +1
my attempt, isn't it -5?
Right, but make sure you know why. If you let x=0, then cos(0)=1, but 2-sin2(0)=2-0=2, which isn't 1. So equation (a) is incorrect.
For #3, there are a few ways to do this, but a good technique to know is cross-multiplying to find the common denominator between two fractions, i.e.
[tex]
\frac{a}{b} \pm \frac{c}{d} = \frac{ad\pm bc}{bd}
[/tex]
a,b,c,d can be either numbers, variables like x, or equations such as x-3 in our case.
So using cross-multiplication,
[tex]
\begin{align*}
\frac{1}{x}-\frac{1}{x-3} &= \frac{a}{x(x-3)} \\
\frac{(x-3)-x}{x(x-3)} &= \frac{a}{x(x-3)}
\end{align*}
[/tex]
Can you solve for a from here?
2x^2 -5x +1
This you should be able to know for sure. Did you substitute -5 back into see if it works?
2x2-5x+1=0
(2x+a)(x+b)=0
Can you find numbers a and b (which could be negative) so that when you multiply everything out, you get back your quadratic equation? In other words, can you factor the quadratic easily? If not, you will have to use the quadratic equation. If you don't remember it, look it up in your book.
[tex]
[/tex]
[tex]
\begin{align*}
\end{align*}
[/tex]
thanks for that first one,
-x/x = a/ x(x-3)
-1 * (x*x - 3x)
-1(x^2 -3x)
-x^2 +3x = a
-x/x = a/ x(x-3)
-1 * (x*x - 3x)
-1(x^2 -3x)
-x^2 +3x = a
No! You can't cancel out something out like that. In other words,
[tex]
\frac{(x-3)-x)}{x(x-3} \not= \frac{-x}{x}
[/tex]
What is the numerator in that equation if you add everything together?
2x2-5x+1=0
(2x+a)(x+b)=0
I think that's my problem, I'm at Uni now and I've just relied on the quadratic equation to get me through those kinds of problems,
but now, as I've said above we aren't allowed to use calculators so yah.
reading about quadratics just now XD
[tex]
[/tex]
[tex]
\begin{align*}
\end{align*}
[/tex]
(x-3)-x / (x^2-3x) = a/ (x^2-3x)
(x-3)-x = a?
But you don't get -5 when using the quadratic equation, and you should have found two roots, not just one (unless they were imaginary). You need to be able to factor out quadratics in your head or on paper, and you also need to realize when you can't quickly factor it out to just resort to the quadratic equation. Learning to factor can just save some time, but the quadratic equation will always get you the roots.
Were you able to finish #3?
(x-3)-x = a?
No reason to multiply out the denominators though. You could have just multiplied by x(x-3) on both sides to cancel the denominators.
What does (x-3)-x equal?
You shouldn't have to memorize all sorts of trig identities; you should be able to manipulate all the trig functions you'll come across in your class using a few basic identities. I can get pretty much anywhere using the sum formula, and sin^2x + cos^2x = 1 (and really fundamental stuff like sinx/cosx = tanx, obviously).
I remember doing trig identities in my Precalculus class. It was like a drill sergeant giving soldiers draconian amounts of push ups. We manipulated probably hundreds of practice trig identities to get them into the form the question wanted -- and I basically never used anything but those few formulas above to get there.
If you have trouble getting a trig function into the right form, just evaluate the trig function at pi/6, pi/4, pi/2, pi, or 2pi. They're all easy numbers to evaluate the trig functions at. Good luck on your tests!
-3 :)
so using the quadratic formula will give you a different awnser compared to factorization?
so for example, x^2 +4x -12
factorizing it, you'd get 6 and -2?
i didn't use the quadratic formula for that
Yes, a=-3 is correct. No. The quadratic equation will always give you the two roots, but factorization can get you the same two roots quicker if the quadratic can be factored easily. For example,
x2-5x+6=0
(x-3)(x-2)=0
Now the roots are x=3,2. If you used the quadratic equation, it would take longer and could possibly lead to a mistake.
right, cheers buddy for all your help
Almost! Your signs are switched. Be sure to use good notation and document your steps.
x2+4x-12=0
(x+6)(x-2)=0
x+6=0 and x-2=0
x=-6 and x=2
1. How do I find the roots of a polynomial equation?
To find the roots of a polynomial equation, you can use the quadratic formula or factor the equation. The roots are the values of the variable that make the equation equal to zero.
2. What is the difference between the roots and solutions of an equation?
The roots of an equation are the values of the variable that make the equation equal to zero. The solutions of an equation are the values of the variable that make the equation true. In other words, the roots are the x-intercepts on a graph, while the solutions are the points on the graph where it crosses the x-axis.
3. Can I have complex roots for a polynomial equation?
Yes, it is possible to have complex roots for a polynomial equation. This happens when the equation has imaginary numbers, such as the square root of a negative number. Complex roots always come in conjugate pairs, meaning if one root is a+bi, the other root will be a-bi.
4. Can I use the graph of an equation to find its roots?
Yes, you can use the graph of an equation to estimate the roots. The roots are the points where the graph crosses the x-axis. However, keep in mind that the graph may not always show all the roots, especially if they are complex roots.
5. How do I check if my calculated roots are correct?
You can check if your calculated roots are correct by substituting them back into the original equation. If the equation equals zero, then the root is correct. You can also use a graphing calculator to plot the equation and see if the roots are located at the expected points.
