Solving Magnet Problems: Minimum Magnetic Field for Horizontal Northward Motion
  • Thread starter wisper
  • Tags
    Magnet
In summary, the conversation discusses the calculation of the minimum magnetic field needed to keep a charged particle moving in the Earth's gravitational field. The formula used is B = \frac{mg}{qv}. The direction of the magnetic field is determined using the right hand rule.
wisper
I am having too hard of a time with such a simple magnet equation that I am starting to loose it.
A particle with a mass of m carries a negative charge of - q. The particle is given an initial horizontal velocity that is due north and has a magnitude of v.
What is the magnitude of the minimum magnetic field that will keep the particle moving in the Earth's gravitational field in the same horizontal, northward direction? Use g for the acceleration due to gravity.
Let the charge be traveling a distance [itex]s[/itex] in time [itex]t[/itex]. Visualise this as a thin wire carrying current in a magnetic and gravitational field.
The current carried by the charge is [tex]I = \frac{dq}{dt} = \frac{qv}{s}[/tex]
A magnetic field directed perpendicular to the motion of charge will exert a force on the wire given by [itex]F = IsB[/itex]. This force has to balance the weight of the "wire" = [itex]mg[/itex].
Hence [tex]mg = IsB = \frac{qv}{s}(s)(B) = qvB[/tex]
Therefore [tex]B = \frac{mg}{qv}[/tex].
That's the magnitude. For the direction, use the right hand rule, but remember that the current in the right hand rule is conventional current, so you need to reverse the direction for negatively charged carriers.
Thank you, for putting it clearly.
Sure. :smile:
1. What is the minimum magnetic field required for horizontal northward motion?
The minimum magnetic field required for horizontal northward motion depends on several factors such as the mass and charge of the object, the strength and direction of the Earth's magnetic field, and the friction force acting on the object. It can be calculated using the equation F = Bqv, where F is the magnetic force, B is the magnetic field, q is the charge of the object, and v is its velocity.
2. How does the Earth's magnetic field affect horizontal northward motion?
The Earth's magnetic field plays a crucial role in determining the minimum magnetic field required for horizontal northward motion. This is because the Earth's magnetic field interacts with the magnetic field of the object, resulting in a force that can either assist or hinder the motion depending on its direction and strength.
3. What is the relationship between mass and the minimum magnetic field required for horizontal northward motion?
There is a direct relationship between the mass of the object and the minimum magnetic field required for horizontal northward motion. As the mass increases, the minimum magnetic field required also increases because a larger force is needed to overcome the object's inertia and friction.
4. How does friction affect the minimum magnetic field required for horizontal northward motion?
Friction can significantly impact the minimum magnetic field required for horizontal northward motion. Friction acts in the opposite direction of motion and can reduce the object's speed, making it harder to overcome the inertia and move horizontally. Therefore, a stronger magnetic field is needed to counteract the friction force and maintain the object's motion.
5. Can the minimum magnetic field for horizontal northward motion be different for different objects?
Yes, the minimum magnetic field required for horizontal northward motion can vary for different objects. This is because it depends on the mass, charge, and other properties of the object. For example, a heavier object may require a stronger magnetic field compared to a lighter object to achieve the same horizontal northward motion. Additionally, the shape and size of the object can also affect the minimum magnetic field required.
