Eccentric anomaly of ellipse-circle intersections
The discussion revolves around calculating the eccentric anomaly of intersection points between a non-rotated ellipse centered at the origin and a translated circle. Participants explore various mathematical approaches and coding implementations, primarily using Python, to solve this problem.
  • One participant shares an initial implementation using numpy to find intersection points but questions the correctness of the calculated eccentric anomalies.
  • Another participant suggests that the parameter used in the circle's parametrization is not an angle and recommends returning the real roots directly without applying modulo 2π.
  • A later reply clarifies the misunderstanding regarding the parameter and provides a revised code snippet for calculating eccentric anomalies based on the intersection points.
  • Further refinements are proposed, including alternative methods to calculate the eccentric anomaly directly from the intersection coordinates using arctan functions.
  • Another participant suggests parametrizing the ellipse instead of the circle, leading to a different polynomial formulation for finding intersection points.
Participants express differing views on the best approach to calculate the eccentric anomaly, with multiple competing methods and refinements presented. No consensus is reached on a single definitive method.
Some participants note limitations in their approaches, such as omitting edge cases or the implications of certain parameterizations. The discussion reflects ongoing exploration rather than settled conclusions.
Marko7
I want to calculate eccentric anomaly of all points of ellipse-circle intersection.
Ellipse is not rotated and its center is in origin.
Circle can be translated to (Cx, Cy) coordinates.
I am using python for calculations.
Only solution I found, is this:
https://math.stackexchange.com/questions/3419984/find-the-intersection-of-a-circle-and-an-ellipse
And I implemented it in my code. I avoided calculating polynomial roots manually by using numpy's solver.
[CODE lang="python" title="ellipse_circle.py"]import numpy as np
def ellipse_circle(a, b, c_x, c_y, r):
"""Calculate eccentric anomalies of intersecting points
on non-rotated ellipse in origin, and translated circle"""
# quartic equation coefficients
a_4 = a**2 * (c_y**2 - b**2) + b**2 * (c_x - r)**2
a_3 = 4 * a**2 * r * c_y
a_2 = 2 * (a**2 * (c_y**2 - b**2 + 2*r**2) + b**2 * (c_x**2 - r**2))
a_1 = 4 * a**2 * r * c_y
a_0 = a**2 * (c_y**2 - b**2) + b**2 * (c_x + r)**2
# quartic equation roots
roots = np.polynomial.polynomial.polyroots([a_0, a_1, a_2, a_3, a_4])
# take only non-complex roots
real_roots = np.real(roots[np.isreal(roots)])
return real_roots % (2*np.pi)[/CODE]
I tested it on some simple example:
>>> ellipse_circle(5, 2.17945, 4.5, 0, 1)
array([5.22599703, 1.05718828])
But those two roots are not eccentric anomalies of intersection points, as can be seen here (Point D is real intersection, and point A is calculated one):
So, what am I doing wrong, how can I calculate eccentric anomaly?
Mathematics news on Phys.org
You are calculating values for the parameter [itex]z \in \mathbb{R}[/itex] in the parametrization of the circle [itex](x-x_c)^2 + (y-y_c)^2 = r^2[/itex] as
[tex]\begin{split}<br /> x = x_c + r \frac{1 - z^2}{1 + z^2} \\<br /> y = y_c + r \frac{2z}{1 + z^2}. \end{split}[/tex] [itex]z[/itex] is not an angle, so I do not think it is necessary or correct to return these modulo [itex]2\pi[/itex], as your program does (see line 20). Replace line 20 with
Python:
   return real_roots
and see if it does any better.
EDIT: Note that the point [itex](x_c - R, y_c)[/itex] is attained only in the limit [itex]|z| \to \infty[/itex]; this corresponds to the coefficient of [itex]z^4[/itex] vanishing. You can test this case by setting cx = -0.5, cy = 0, r = 0.5, a = b = 1.
I also now see from your diagram that you have misinterpreted the root 5.22 as being an angle in radians about the origin (5.22 rad ~ 299 deg); it is not. You need to use the above parametrization of the circle to recover the x and y coordinates. The eccentric anomaly can then be calculated as [tex] \arccos\left(\frac{1}{\sqrt{1 - b^2/a^2}}\left(1 - \frac{\sqrt{(x-ae)^2 + y^2}}{a}\right)\right)[/tex] as shown here.
I had no idea that parameter is from circle.
I thought that parameter ##z## is same as parameter ##t## as used in normal parametric equations.
Here is working code if anyone in future needs it:
import numpy as np
if any(real_roots):
# calculate x and y coordinates
x = c_x + r * (1-real_roots**2) / (1 + real_roots**2)
y = c_y + r * 2 * real_roots / (1 + real_roots**2)
ecc = np.sqrt(1-(b**2/a**2))
# eccentric anomaly
ea = np.arccos((1/np.sqrt(1-(b**2)/a**2)) * (1-(np.sqrt((x-a*ecc)**2 + y**2)/a)))
ea = np.where(real_roots < 0, 2*np.pi-ea, ea) # quadrant corrections
return ea
else:
return np.array([])
[/CODE]
Note: because of square roots in line 23, calculated angle is in range (0, ##\pi##), which is corrected in line 24.
Resulting eccentric anomaly is in range (0, ##2\pi##).
In my simulation it is very unlikely that this edge case with ##z^4## coefficient being zero will occur, so I just omitted it to save computation time.
Thanks. Helped a lot!
Thinking again, it is simpler to obtain the anomaly from [itex](x,y)[/itex] as
Python:
np.arctan2(np.sign(y)*np.sqrt(a**2 - x**2),x)
since the auxiliary circle of the ellipse is [itex]x^2 + y^2 = a^2[/itex].
EDIT: Simpler still is
Code:
atan2((a/b)*y, x)
since [itex](x,y) \mapsto (x,(a/b)y)[/itex] maps the ellipse [itex](a\cos\theta, b\sin \theta)[/itex] to the circle [itex](a \cos \theta, a \sin \theta)[/itex].
A further refinement is to parametrize the ellipse, rather than the circle, as [tex]\begin{split}<br /> x &= a\frac{1 - z^2}{1 + z^2} \\<br /> y &= b\frac{2z}{1 + z^2} \end{split}[/tex] and then the values of [itex]z[/itex] at the points of intersection are the roots of [itex]P(z) = \sum_{n=0}^4 a_nz^n = 0[/itex] where [tex] \begin{split}<br /> a_0 &= a^{2} - 2 a c_{x} + c_{x}^{2} + c_{y}^{2} - r^{2} \\<br /> a_1 &= - 4 b c_{y} \\<br /> a_2 &= - 2 a^{2} + 4 b^{2} + 2 c_{x}^{2} + 2 c_{y}^{2} - 2 r^{2} \\<br /> a_3 &= - 4 b c_{y} \\<br /> a_4 &= a^{2} + 2 a c_{x} + c_{x}^{2} + c_{y}^{2} - r^{2}<br /> \end{split}[/tex] The anomalies are then obtained by
Python:
    np.atan2(2*z, 1.0 - z**2 ) for z in roots if np.isreal(z)
with the addition of [itex]\pi[/itex] if the degree of [itex]P[/itex] is less than 4.
  • · Replies 30 ·
