How Is the Rate of Mass Loss from the Sun Estimated Using Solar Wind Data?
  • Thread starter Thread starter AStaunton
    Luminosity
AStaunton
Hi there
Problem is:
Assuming spherical Symmetry, estimate the rate of mass loss from the sun, if at the Earth, the measured velocity of the solar wind is 400km/s and the proton density of the wind is roughly 7 particles/cm^3. Give your answer in solar Masses per year.
My attempted solution:
as proton density is 7particles per cm^3 this equals 7*10^6 particles per m^3.
as the speed is 400km per sec this is 4*10^5m per sec
multiply these values to get proton flux:
(7*10^6)*(4*10^5)=2.8*10^12protons m^-2 s^-1
find the surface area of the relevant sphere, this will have radius of 1AU as this flux is measured at the Earth:
A=4*3.14*(1.49598*10^11)^2=2.810873*10^23m^2
now we can find the total protons passing through the entire surface and of course this equals total protons leaving the sun:
(2.810873*10^23)*(2.8*10^12)=7.87044*10^35 protons s^-1
convert this to kg per second:
say proton mass= 1.6727*10^-27kg
so (7.87044*10^35)*(1.627*10^-27)=1316409794kg s^-1
convert to kg per year:
31536000 seconds per year so:
1316409794*31536000=4.151429928*10^16kg per year
find what fraction this mass is of the mass of sun:
(4.151429928*10^16)/(2*10^30)=2.0757*10^-14
so that means mass lost per year this way is (2.0757*10^-14)solarmasses per year.
When I first read this question, I thought it would involve some calculations regarding the Eddington Luminosity as this is what governs how much mass is blown away...however, the final method that I used did not need that, so can someone please confirm that I did not miss anything or over simplify?
Also, the question speaks of protons in the solar wind, is it safe to assume (as I did in the solution) that these are the only particles blown away?
Any feedback appreciated.
Please note, I accidently posted two identical threads...only one of them is necessary!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
