altergnostic said:
Thanks for the responses.
I say negative tide because it is a negative bulge, oposite to the bulge predicted by tidal theory.
None of the theories explain all the features. For instance, the near side could have been heavily impacted to explain the negative bulge, but then you'd have to explain why there's no flattening at the poles, or no tide on the far side. Flattening at the poles and tides on the near and far side are a direct prediction of tidal theory, and a body in tidal lock should have these features increased.
Current tidal theory is based on Newton, with gravity as a pulling force at a distance. In GR, gravity is the shape of the field (space-time), and there are no forces (Einstein said so explicitly). Without forces, there's no mechanism for tidal theory to rely on, so we stick with Newton. So is gravity an attractive force or the geometry of the field? We can't have it both ways. Does this bother anyone else or is it just me?
But back to the moon. Darwin123 said that "Tidal force is only one possible mechanism for breaking the symmetry", but that's backwards, tidal theory predicts a tidal symmetry front and back, not a breaking symmetry. It's not that "Tides do not explain the asymmetry of the moon too well". It's that they explicitly contradict the evidence.
I agree with you. Tides do not explain the asymmetry. I only mentioned tides as "one possible reason" because one of the links that I posted mentioned it.
There are unlikely ways that tides could cause symmetry breaking. The usual expression of the tidal forces are characterized by the dipole contribution of the gravitational potential. However, there are some ways the octopole component could get involved.
I can visualize some of these. However, I don't have references. I suspect there are no references because the actual calculations show it can't happen.
For instance, the Earth equator is tilted with respect to the moons orbit. The tides would no longer center on the equator. The spin of the Earth could create some asymmetry.
I basically agree with you. The hemispherical asymmetry seen on the moon are far too big to be caused by tides. For completeness, I wanted to include this highly unlikely scenario which is also the most "obvious" to people who don't understand tides.
altergnostic said:
The proposition that objects in lower orbits wrt Earth would be moving faster and therefore cause more damage on the near side is a bit ridiculous and I can't take it seriously.
You are misrepresenting the theory. It isn't just that the nearside collisions do more damage.
Before the moon cooled to the "freezing point", more objects impacted on the nearside than the farside. The number concentration of objects will be higher on the nearside. The velocity of the objects will be greater on the nearside. So the flux of impacting objects will be greater on the nearside.
The extra nearside collisions thinned the crust. They didn't immediately cause the visible features seen on the nearside. The maria seen on the nearside aren't craters in the usual sense. They are lava flows. Meteors punched holes in the thinner crust.
The asymmetric crust formed while the moon was still hot. Nearside collisions caused the nearside crust to remain hotter longer, forming a thin crust. After the moon cooled off a little, the crust was thinner on the nearside than the far side. After it cooled of a bit, meteors came an punched holes in the crust.
The problem is the thinner crust on the nearside than the far side. The lava flows are asymmetric because of the asymmetric crust. It appears to me that whatever initially caused the asymmetry must have been a slow process. Just not tides.
altergnostic said:
By that reasoning, the moon should have an even larger lateral asymmetry, since tangential impacts would be less energetic than direct impacts on the trailing and leading sides of the moon. That's why it was proposed that the moon was differently oriented in the past, but that's such a wild guess that I could just as easily propose that it was upside down, or retrogade, or pink. This is particularly obvious considering the other theory that proposed a different orientation, where the far and near side would be reversed, and then proposing that impacts from the outer regions would cause the negative bulge we presently see. What caused all this flipping? Again, you can propose anything you like, so this is all as far from satisfactory as you can get.
The collisions that caused the asymmetry in this theory occurred before the crust completely cooled. The crust was still "liquid". It took a long time for the crust to cool, so there was time for magma to flow. So damaged caused by individual meteor strikes was "washed out". The flow eliminated the small scale "damage". All that was left was the thinner crust.
altergnostic said:
Geological explanations are even wilder. Say the moon has an uneven core, it isn't necessarily concluded that the surface would follow it's shape. If you can propose a complex mechanism to convince that the core is asymmetric, you can just as easily propose other mechanisms to explain any shape you like, any relations between core, mantle and surface, and with enough postulated mechanisms you can have a triangular core with a oblong surface or what have you. And even if the core happens to match the shape of the surface, the causes are still just assumptions. So we have assumptions over assumptions over assumptions where with impact-based theories you had just assumptions over assumptions.
I don't know the answer to all this, of course, and I would be speculating just like everyone if I made any suggestions, but let me point out that gravity is not fully understood, and maybe not understood enough to fully describe tides. The history of the perihelion of mercury problem should teach us a lesson. Instead of believing Newton's gravity was complete and start looking for hidden planets to explain data on mercury, we could only find a partial solution when Einstein reviewed Newton, and precisely because that same theory explained other phenomena. Shouldn't we stop looking for hidden bodies impacting a differently oriented moon and base tidal theory on Newton? If GR is an improved description of gravity and if we really have ditched force at a distance, we should use GR to explain tides, and if that seems impossible, either GR is not a complete theory of gravity or gravity is not the cause of tides. There's no third choice, is there?
This is nonsense. Gravity is the best know of all the forces that govern the dynamics of the solar system. Newton's Laws seem to govern geological processes sufficiently well that few geologists have to even consider General relativity. General relativity causes very small deviations from Newon's Laws that are easily calculated, even when they are insignificant.
Deviations from General Relativity may occur on distance scales comparable to the diameter of the visible universe. There are strange observations concerning the dynamics of galaxies and galactic clusters that some scientists think may be caused by a deviation from General Relativity. However, nothing in the solar system has a distance scale comparable to these distances.
There is no evidence that gravity behaves any differently on the distance scale of the solar system then it behaves on earth. Every experiment with "simple" systems shows that General Relativity is sufficiently accurate to predict orbital behavior within this solar system. Newton's Law of gravity is a sufficiently good approximation for geochemistry purposes.
Playing around with Newton's Laws of gravity just adds more unknowns to problem. Even without a deviation from Newton's Law, there are more unknowns that variables. So your suggestion probably won't be helpful.
There are a lot of other unknowns. As you point out, there are so many more variables than there are unknowns that multiple models seem to work. However, the laws of gravity are not one of the unknowns.
altergnostic said:
After all, is there any evidence supporting tidal theory on other bodies in our solar system? Are there any moons that show the predicted tides, even if not in tidal lock? I couldn't find any. Is tidal theory supported only here on Earth?
Tidal theory? You mean gravitational theory! There is no "tidal theory". If a theory of gravity is validated, then it confirms tidal theory. That is why you didn't find anything in your search. "Gravity theory" works fine in this solar system.
The law of gravity has been validated all over the solar system by our space probes.
There is a questionable deviation of one of our space probes that left the solar system. However, the moon orbit is not nearly as long as the distance this space probe went.
