Schools Effect of Research/Publications on Grad School Admittance
Research experience in both physics and chemical engineering is emphasized as a significant asset for graduate school applications, particularly with plans to publish multiple papers. Being first author on publications is viewed as a strong advantage, potentially enhancing chances of admission to top graduate programs. While a GPA around 3.5 may be considered average, a high GRE score and robust extracurricular involvement can help offset it. The importance of strong references from well-regarded professors is highlighted as critical for improving admission prospects. Overall, the combination of publications, GRE performance, and solid recommendations is seen as key to gaining entry into competitive programs.
EE_physics
Hello! I currently do research for the physics department and also the chemical engineering department of my university (ranked within top 100, if I remember correctly, for context). I should be publishing at least three or more papers through this research during my time here, though I'm shooting for around five or six if results all go as expected.
I was told by the chem.e research head that being first author on a publication is nearly a guarantee into any grad school program that I want. How true is this? I'd like to go for a top 15 school if possible, but my GPA will likely be around 3.5 by the time I graduate if I'm being fair. My GRE should be decent (I always score high on practice ones) and I have a ton of extracurriculars and leadership roles, as well as work experience.
What do you guys think of my chances, given some pretty vague information?
Based on the information you gave, I would say you're chances are 50/50... Probably.
Hallo
first of all I have to tell you that I do not know really exactly how things work in the US... but I searched for some information to be able to go there somewhere for the PhD and I also did some applications in Canada (where it is the same thing) so I perhaps can help you.
The number of publications is for sure important (at least if they are peer reviewed, i.e. if they are published in specialized journals which check things seriously before publishing them). Anyway the most important thing there are the references. Try to have good marks at your GRE, try to publish most you can but more important try to convince (with your work mainly) some good professors to give you references. If they are known around and if they speak well about you, your possibilities improve for sure.
Good Luck
Tia
p.s. anyway good job so many publications before the degree. I m doing my Master of Science in physics, and I am preparing the thesis... but I am one of the lucky ones if I manage to publish one work... here most of people do not publish anything before the PhD. I am lucky because I am doing my thesis in a research centre instead than at my University so my supervisor there will probably let me publish my work before discussing the thesis
Thanks for all the responses guys!
My GRE should be very high. I took a practice exam and scored pretty decently.
Since my GPA may be meh, I'm really hoping that the GRE and publications will carry me where I need to go.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
