Effect of Voltage Increase on Battery Wattage
The discussion revolves around the effects of increasing voltage from a 3.7V battery to 12V on power consumption and battery discharge rates. Participants explore the implications of voltage changes in relation to power, current, and circuit design, with a focus on practical applications and limitations.
  • Some participants question whether increasing voltage affects the wattage consumed from the battery or the rate of discharge.
  • One participant emphasizes that power is not solely dependent on voltage, suggesting that other factors must be considered.
  • Another participant mentions the specifications of a blower and battery, indicating a practical scenario but not addressing the initial question directly.
  • Concerns are raised about the understanding of basic electrical principles, such as Ohm's Law and the equations for power.
  • Some participants argue that power remains constant regardless of voltage changes, noting that increasing voltage would decrease current to maintain the same power output.
  • There is a suggestion to use multiple batteries in series to achieve the desired voltage, but skepticism is expressed regarding the practicality of boosting voltage for powering a fan.
  • One participant highlights the need for a circuit to convert DC voltage, noting the complexity involved in such conversions.
  • A later reply warns that using a module to boost voltage could lead to high current draw from the battery, potentially depleting it quickly.
Participants express differing views on the implications of increasing voltage, with no consensus reached on the best approach for powering devices or the effects on battery life. Some participants challenge the understanding of basic concepts, while others provide practical insights.
Limitations include varying levels of understanding among participants regarding electrical concepts, the complexity of voltage conversion, and the assumptions about battery capabilities and circuit design.
Kussy
If we boost voltage from 3.7v to 12v, is this will affect on watt we consumption from the battery or make your battery discharge faster?
Power is not a function of just voltage. What else does it depend on?
I have blower 12V 280mAh the power source Battery Li ion 3.7V 2200mAh
Ok, that's nice, but you didn't answer my question. Do you understand simple circuits? Do you understand Ohms Law? Do you know the equation for power?
I understand that you think you are asking a very simple question, but you are not. It depends on more than you seem to think it does and you have given no indication of your level of understanding of electronics.
Power is power regardless if you raise the voltage. Perhaps a buck/boost...you can't use a normal transformer in DC. If u raise the voltage, you lower the amps to make same power. If you lower the voltage, you raise the amps to make the same power. The battery should last just as long either way.
But then again, why on Earth would you boost a battery to power a fan? Or are you just talking in hypothetical sillyness as younger folk often do on here?
You could wire four of your batteries in series to make 14.8 volts. (3.7 X 4 =14.8)
Again, why would you? Why not power a 12 volt fan with a 12 volt battery? or perhaps an AC source transformed down to 12 volts?
Quick course for you.
V=IR, Voltage = Current X Resistance
P=IV, Power = Current X Voltage
Look at the P=IV especially...see?
I have limit knowledge about power and electronics, psparky about why, because I have limit space and limit weight
my knowledge is limit and know its complicated for that reason I am asking I want to reduce my errors
Well, here's the thing. As psparky pointed out, you cannot use a transformer to convert DC to DC voltage, you need a circuit to do it. It is somewhat complicated and not something you want to do if you do not have the knowledge.
If you can BUY a converter then the issue you face is simply whether or not the battery can provide enough power. I think it will, but only for a little while. I agree w/ psparky that you should just use a 12V battery.
If you buy a module to achieve this it will drain about 1000mA from your battery. So your battery will soon go flat.
  • · Replies 49 ·
  • · Replies 53 ·
