Eigenfunction of electron in E and B fields
5 replies · 3K views
Yaelcita
Consider a free electron in a constant magnetic field [tex]\vec{B}=B\hat{z}[/tex] and a perpendicular electric field [tex]\vec{E}=\varepsilon\hat{y}[/tex]. Find the energy eigenvalues and eigenfunctions in terms of harmonic oscillator eigenfunctions
Hint: Use Landau gauge [tex]\vec{A}=-By\hat{x}[/tex]
What I actually don't understand is at the end... read on
The Hamiltonian of a charged particle in an external em field is
[tex]H=\frac{1}{2m}\left(\vec{p}-\frac{q}{c}\vec{A}\right)^2+q\phi[/tex]
The hint says to use [tex]\vec{A}=-By\hat{x}[/tex] and since [tex]\vec{E}=-\nabla\phi[/tex] I can make [tex]\phi=-\varepsilon y[/tex]
Plug in expressions for A and [tex]\phi[/tex] into H, which gives
[tex]H=\frac{1}{2m}\left(p_x^2+p_y^2+p_z^2+\left(\frac{qB}{c}\right)^2y^2+\frac{qB}{c}p_x y\right)-q\varepsilon y[/tex]
I know I just have to play around with this expression to make it look like a harmonic oscillator, but I have no idea how... In another problem that I solved, I used an A potential with both an x and a y components, but I didn't have the scalar potential in that case. It's that term that ruins everything!
Any ideas??
The scalar potential, which is just proportional to y, should only serve to change your equilibrium position for your harmonic oscillator. Kind of like gravity acting on a spring. I think you can make coordinate transformations to this new equilibrium position.
I'm not 100% sure on this, but see if you can do something with it.
Ok, let's see...
Let [tex]y=y'+\frac{\varepsilon m c^2}{q B^2}[/tex]. Now the Hamiltonian reads (ignoring the unimportant parts):
[tex]H&=&\frac{1}{2m}\left(p_x+\frac{qB}{c}\left(y'+\frac{\varepsilon mc^2}{qB^2}\right)\right)^2-q\varepsilon\left(y'+\frac{\varepsilon mc^2}{qB^2}\right)[/tex]
[tex]&=& \frac{1}{2m}\left(p_x+\frac{qB}{c}y'+\frac{\varepsilon mc}{B}\right)^2-q\varepsilon y'-\frac{\varepsilon^2mc^2}{B^2}[/tex]
[tex]=\frac{1}{2m}\left(p_x+\frac{qB}{c}y'\right)^2+\frac{m}{2}\left(\frac{\varepsilon c}{B}\right)^2+\left(p_x+\frac{qB}{c}y'\right)\frac{\varepsilon c}{B}-q\varepsilon y'-\frac{\varepsilon^2 mc^2}{B^2}[/tex]
[tex]=\frac{1}{2m}\left(p_x+\frac{qB}{c}y'\right)^2-\frac{mc^2\varepsilon^2}{2B^2}+p_x\frac{\varepsilon c}{B}[/tex]
I think I know what to do with the stuff in parenthesis, but I don't know how to get rid of the constant term and the [tex]p_x[/tex] term... Do they matter? I guess I don't really know how to continue after all...
I'm not sure I follow your substitution (also, where'd all the py and pz's go?). Actually, the momentum in the y direction is the momentum you want to couple with the y's to get a harmonic oscillator.
Hmm, perhaps someone better at this can help you. It's been a while since I've actually worked out problems like this.
I just didn't write it, since I was working only with those two terms...
I know, but I have the solution to this one problem where they then go on to define raising and lowering operators as [tex]x\pm i p_x[/tex] and the same for y, and they get the Hamiltonian to look like the product of a raising and a lowering operator plus a half, so I thought if I could make it look like that I could just use that solution, but I don't know what to do with the constant term, and the p_x term, more importantly.
Well, the constant isn't going to mess with the eigenfunctions right, you can just bring it to the other side of the eigenfunction equation.
H*psi=E*psi
So, you can just bring the constant over to the right side of the equation, and it would only adjust your eigenvalue.
The px part also stumps me...
