Possible Values of Angular Momentum in a Rigid Rotor?
The discussion focuses on determining the possible values of the z component of orbital angular momentum for a rigid rotor in a given quantum state. The wavefunction provided is a superposition of spherical harmonics, specifically related to the angular momentum quantum numbers l and m_l. It is concluded that the possible values of angular momentum are l=1 and l=-1, with the corresponding probabilities calculated using the coefficients of the spherical harmonics. A key point made is that the coefficients in the linear combination can be complex, allowing for the correct representation of the wavefunction. The conversation emphasizes the importance of understanding superpositions in quantum mechanics.
IHateMayonnaise
[SOLVED] Eigenstates and Angular Momentum
At a given instant, a rigid rotor is in the state:
\Psi(\theta,\phi)=\sqrt{\frac{3}{4\pi}}Sin(\phi) Sin(\theta)
If the z component of the orbital angular momentum is measured, what are the possible values of <\hat{L_{z}}>, and with what probability will they occur?
These are the equations that I think are relevant:
\hat{L_z}=\frac{\hbar}{i}\frac{\partial}{\partial \theta}
L_z = m_l \hbar
|m_l| \leq l
<\hat{L_z}>=\int_0^{2\pi} \Psi^*(\theta, \phi)\left(\frac{\hbar}{i}\frac{\partial}{\partial \theta}\right)\Psi(\theta, \phi) d\phi
Y_1^1=-\sqrt{\frac{3}{8\pi}}Sin(\theta)e^{i\theta}
Y_1^{-1}=\sqrt{\frac{3}{8\pi}}Sin(\theta)e^{-i\theta}
...and also the exponential identities for Sine and Cosine.
I suppose my question really has to do with the nature of the wavefunctions defined by Spherical Harmonics. Since the solution to The Schrodinger Equation in spherical coordinates has solutions that correspond to Spherical Harmonics (i.e., Y_l^{m_l} corresponds to \Psi(\theta,\phi) above), it seems like we should only be able to get solutions (ie wavestates) that are in this form! And while \Psi(\theta,\phi) is close to both Y_1^1 and Y_1^{-1}, it isn't the same. Furthermore, it looks like it could be a superposition of the two, but it's not!
So, really, I need to find l and m_l. Since our \phi dependence in our wavefunction has a coefficient of 1 (i.e. Sin(\phi) corresponds to e^{im_l\phi} where m_l=1). So, l can have the possible values of +1 or -1. But, like I stated in the above paragraph, neither Y_1^1 or Y_1^{-1} correspond to our wavefunction! So what the hell is m_l and l?
L_z = m_l \hbar
|m_l| \leq l
why? A general solution is a linear combination of the eigenstates. Nothing says that a physical system must absolutely be an eigenstate of an operator (unless this operator was measured and we consider the state just after the measurement)
Of course it's a superposition. Look at it carefully and you can write it as a linear combination.
Okay, so it is a superposition of l=1 and l=-1, so those are the two possible values of the orbital angular momentum, right?
If I wanted to find the probability of each wouldn't I just compute:
|a_1|^2=<\Psi(\phi),e^{i\phi}>^2?
(here \Psi(\phi) is equal to \Psi(\theta, \phi) except without the theta dependence?)
No you would compute
|<\Psi(\theta,\phi),Y_1^1>|^2 and so on. (Of course if you write the explicit expansion in term of the Y_m^l, you can also read of directly the coefficients.)
Ok so I actually don't see how it's a linear combination of Y_1^1 and Y_1^-1...because every time I do the computation I get:
-i\sqrt{\frac{3}{4\pi}}Sin(\theta)Sin(\phi)
I can't get rid of that -i! Any thoughts?
just multiply your coefficients by +i !
Nothing says that the coefficients have to be real.
I'm sorry but I don't understand! Why can you just "multiply by i" ?
What I mean is that if you have
c_1 Y_1^1 + c_2 y_1^{-1} = -i\sqrt{\frac{3}{4\pi}}Sin(\theta)Sin(\phi)
for some c_1 and c_2, then obviously
i c_1 Y_1^1 + i c_2 y_1^{-1} = \sqrt{\frac{3}{4\pi}}Sin(\theta)Sin(\phi)
So if you use i c_1 and i c_2 as your coefficients, you get the correct answer!
