Eigenvalue of vector space of polynomials
specialnlovin
Let V=C[x]10 be the fector space of polynomials over C of degree less than 10 and let D:V\rightarrowV be the linear map defined by D(f)=f' where f' denotes the derivatige. Show that D11=0 and deduce that 0 is the only eigenvalue of D. find a basis for the generalized eigenspaces V1(0), V2(0), V3(0)
I get that D11=0 because a polynomial with degree 10 has an 11th derivative equal to zero since. However I am not sure how exactly to write that in a proof, also how to then deduce that the eigenvalue must equal zero.
I also don't know exactly how to start the problem of finding a basis for the eigenspaces.
If f is in V, so it's a polynomial of degree n<=10, what's the degree of D(f)? What does that tell you about the possibility of a nonzero eigenvalue?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
