Understanding Einstein Notation for Derivatives of Fields
So if I set both equations equal to 0, then the metric drops out and they are equivalent. Got it.In summary, two expressions in their covariant and contravariant forms may not necessarily be equal. However, if they are both set equal to zero, then the metric will drop out and they will be equivalent. Partial derivatives also commute when the metric is constant.
ehrenfest
2,020
Is [tex] \partial ^ {\nu} F_{\mu \nu} + m^2 A_{\mu} [/tex] the same expression as [tex] \partial _{\nu} F^{\mu \nu} + m^2 A^{\mu} [/tex]?
What form of the metric do I need to hit them with to show that?
Also is
[tex] \partial ^{\nu} \partial_{\mu} A_{\nu} = \partial_{\mu} \partial ^{\nu} A_{\nu} [/tex]
EDIT: I changed the second expression so it makes sense.
ehrenfest said:
Is [tex] \partial^{\nu} F_{\mu \nu} + m^2 A_{\mu} [/tex] the same expression as [tex] \partial _ {\nu} F_{\mu \nu} + m^2 A^{\mu}[/tex]?
No. The second expression does not make sense to start with since in the F term the two mu are downstairs. Did you mean F with with indices upstairs? If so, the tewo expressions could still not be equal since one would be a covariant vector and the other one a contravariant vector.
Two tensors may only be equal if they have the same number of covariant and contravariant indices.
Yes. That's the danger of copying and pasting. I changed it so it makes sense.
Ad 1) You wrote down the covariant and contravariant form of the same expression. You can convert between them by just writing metric tensors in between, e.g.
[tex] m^2 A^{\mu} = m^2 g^{\mu\nu} A_\nu [/tex]
and similar for the first term. But the expressions are not the same, so do not expect the metric to drop out in the end.
Ad 2) Your question is if
[tex] g^{\nu\lambda} \partial_{\lambda} \partial_{\mu} = \partial_{\mu} g^{\nu\lambda} \partial_{\lambda} A_{\nu},[/tex]
that is, do partial derivatives commute?
AFAIK they do, and the identity at least holds when the metric is constant (that is, [itex]g_{\mu\nu}[/itex] does not explicitly depend on the coordinate w.r.t which you are differentiating).
But if they are both set equal to 0 then the metric will drop out and they are indeed precisely the same equations, right?
Ah, if the expression is equal to zero, then it's a special case. In general, one cannot say that a covariant expression is equal to its contravariant equivalent. But if the covariant expression is equal to zero then its contravariant counterpart will be equal to zero, indeed.
OK. Thanks.
What is Einstein notation?
Einstein notation, also known as Einstein summation convention, is a system of notation used in mathematics and physics to simplify and compactly write equations involving tensors and vectors. It involves using repeated indices to denote summation over those indices.
Why is Einstein notation important?
Einstein notation is important because it allows for a more concise and elegant representation of mathematical equations involving tensors and vectors. It also helps in simplifying complex equations and making them easier to understand and manipulate.
How is Einstein notation used?
Einstein notation is used by replacing repeated indices in an equation with a summation symbol. For example, instead of writing out the components of a vector or tensor individually, they can be represented by a single index that is repeated in the equation.
What are the benefits of using Einstein notation?
The benefits of using Einstein notation include simplifying complex equations, reducing the number of terms in an equation, and making it easier to identify patterns and relationships between different variables. It also helps in performing calculations more efficiently.
What are the limitations of Einstein notation?
One limitation of Einstein notation is that it can be difficult to read and understand for those who are not familiar with it. It also does not work for all mathematical equations and may not be applicable in certain situations, such as when dealing with non-linear equations.
