Elastic collision and inelastic collision
The discussion revolves around understanding elastic and inelastic collisions involving two blocks and a spring. In the inelastic case, the blocks stick together, and the participant calculates the maximum compression of the spring as 0.1551 m but struggles with determining the percentage of energy lost to the environment, which is around 42.86%. For the elastic collision scenario, the participant incorrectly assumes no energy is stored in the spring post-collision, leading to confusion about energy conservation principles. The conversation highlights the importance of recognizing that while kinetic energy is not conserved in inelastic collisions, it is conserved in elastic collisions, and the spring's potential energy must be accounted for. The participant seeks clarification on these concepts to improve their understanding and problem-solving skills.
andylie
Hi everyone, I am stuck with this problems.
A block (m1 = 2.5 kg) sits at rest on a horizontal frictionless surface, connected to an unstretched spring (k = 190 N/m) whose other end is fixed to a wall. Another block (m2 = 1.0 kg) whose speed is 4.0 m/s collides head-on with it.
http://www.webassign.net/hrw/10_44alt.gif
a.) If the two blocks stick together after the collision,
of the initial mechanical energy of the (m1, m2 & spring) system:
how much is lost to the environment during the collision? _____ %
how much is stored in the spring at maximum compression? _____ %
what is that maximum compression of the spring (when the blocks momentarily stop)?
0.1551 m (i got this one right)
b.) If the two blocks instead collide elastically,
what will be the speed and direction of each block immediately after the collision?
block 1: _____m/s,
block 2: _____m/s, left( travel to the left is the right answer)
of the initial mechanical energy of the system:
_____how much is lost to the environment during the collision? %
_____how much is stored in the spring at maximum compression? %
(Where is the rest of the energy?)
what will be the maximum compression of the spring afterwards?
_____m ( i put 0meters since this is elastic collision, because the spring will compressed and return to its initial state, but the answer is wrong)
This is about momentum and conservation of energy
formula:
(i=initial. f=final)
momentum conservation
pi=pf
(m1v1)i+(m2v2)i=(m1v1)f+(m2v2)f
energy conservation (KE=kinetic energy, PE=potential energy)
Ei=Ef
KEi+PEi=KEf+PEf
(1/2mv^2)i+(mgh)i=(1/2mv^2)f+(mgh)f
heres how i find the maximum compression of the spring
first i use momentum conservation equation
(2.5*0)+(1*4)=(2.5*vf)+(1*vf)
4=(2.5+1)vf
4/(2.5+1)=vf=1.1428m/s
now i need to find the maximum distance the spring compressed
so i already know the velocity of (m1+m2) when they start compress the spring.
i set up the equation as
KEblock=KEspring
1/2mv^2=1/2kx^2 (where k is spring constant of 190N, x is distance)
we are looking for x, so i rearrange the equation
((1/2mv^2)*(2/k))^(1/2)=x
((mv^2)/k)^(1/2)=x
((3.5*1.1428^2)/190)^(1.2)= x =0.1551m
how much is lost to the environment during the collision? _____ % (inelastic)
i didnt get this one right, but this is how i do
KEi=KEf
KE(block2)=KE(block1+2)+PEspring
(1/2m2v^2)=(1/2(m1+m2)v^2)+(1/2kx^2)
(1/2*1*4*2)=(1/2(2.5+1)*1.1428^2)+(1/2(190)*0.1551^2)
8=2.28548+2.2843
8=4.5707
to find percent lost
((KEfinal-KEinitial)/KEinitial)*100)=((4.5707-8)/8)*100)=42.86% ( either this or -42.86% is wrong)
I have tried 2-3 times on some problems but i can't get it right. If anyone can explain and show me what equation should i use for all of them, i am really grateful because i am a person that learn through visual not listen. Again, thank you for your help and i really appreciate it
block 1: _____m/s,
formula:
pi=pf
Ei=Ef
KEi+PEi=KEf+PEf
4=(2.5+1)vf
KEblock=KEspring
((mv^2)/k)^(1/2)=x
KEi=KEf
8=2.28548+2.2843
8=4.5707
In an inelastic collision, the kinetic energy isn't conserved. You found the kinetic energy before the collision is 8.00 J. Immediately after the collision, the kinetic energy is 2.29 J. How much was lost?
The spring doesn't have kinetic energy. The energy it has is potential, so you shouldn't have the spring term in there. Also, right after the collision, when the masses move with speed vf=1.14 m/s, the spring isn't compressed, so it again doesn't make sense to add in the term you did, which is when the spring is compressed and the blocks are stopped.
Thank you, i got that one correct now. how about this one?
how much is stored in the spring at maximum compression? ____%
Since the kinetic energy of the block will be stored in the spring until the spring reach max compression
so i set the equation as
KEblock=PEspring
1/2(m1+m2)v^2=1/2kx^2
1/2(3.5)(1.1428^2)=1/2(190)(0.1551^2)
2.28548=2.28532
percent difference is
((PEspring final - KEblock final)/KEblock final)*100
((2.28532-2.28548)/2.28532)*100= -.00700%
so total percentage of energy stored is 100-0.007=99.992%
is that correct? i already tried 4 times and 1 more time error i will lose the point. thanks
The spring force is conservative. What does that imply?
Is my answer correct? i plug in 99.99% of the energy is stored in the spring but its wrong.
I don't mean to be rude and i really appreciate your help if you can just tell me what i did is right or wrong and show me how to approach this problem instead of asking me back what am i thinking.
If i am smart and good in physics i wouldn't go around asking for help.
No, your answer is wrong. This is a conceptual question. If you understand the concepts, the answer is obvious — no calculation needed. That's why I pointed out that the spring force is conservative.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
