Elastic Collision: Calculate the Percent Change in KE
In summary: This is an algebra problem. You can check your work more easily if you start with ##v_{2f} = 0##, as it should be.
arizona1379
A 0.26 kg cue ball with a velocity 1.2 m/s collides elastically with a 0.15 kg billiard ball at rest.
What percentage of the initial kinetic energy is transferred to the billiard?
m1= 0.26kg
Vi1= 1.2 m/s
Vf1= ?
m2= 0.15kg
Vi2= 0 m/s
Vf2= ?
(m1v2+m2v2)i=(m1v2+m2v2)f
ΔKE= ((.5)(m1)(Vi1)2+(.5)(m2)(Vi2)2)i -((.5)(m1)(Vf1)2+(.5)(m2)(Vf2)2)f
%ΔKE= 100(F-I/I)
(0.26kg)(1.2m/s)+0=(0.26kg)(-vf1)+(0.15kg)(-vf2)
(0.312 kg m/s)=(0.26kg)(-vf1)+(0.15kg)(-vf2)
(0.312 kg m/s)-(0.26kg)(-vf1)= (0.15kg)(-vf2)
(0.312 kg m/s)+(0.26kg)(vf1)= (-0.15kg)(vf2)
((0.312 kg m/s)+(0.26kg)(vf1))/(-0.15kg)=(vf2)
(0.312 kg m/s)=(0.26kg)(-vf1)+(0.15kg)[[(0.312 kg m/s)+(0.26kg)(vf1)]/(-0.15kg)]
(0.312 kg m/s)=(0.26kg)(-vf1)-[(0.312 kg m/s)]-[(0.26kg)(vf1)]
(0.624 kg m/s)=(0.26kg)(-vf1)-[(0.26kg)(vf1)]
(0.624 kg m/s)=(-0.52vf1)
vf1= -1.2 m/s
((0.312 kg m/s)+(0.26kg)(-1.2 m/s))/(-0.15kg)=(vf2)
((0.312 kg m/s)+(-0.312 kg m/s))/(-0.15kg)=(vf2)
0=vf2
ΔKE= ((.5)(0.26kg)(1.2 m/s)2+(.5)(0.15kg)(0 m/s)2)i -((.5)(0.26kg)(Vf1)2+(.5)(0.15kg)(Vf2)2)f
The answer is suppose to be 93%
That's one of the equations you'll need. Since you have two unknowns, you'll need a second equation. Besides momentum, what else is conserved?
vf1= -1.2 m/s
You must have made a mistake somewhere. There's no way to solve for either final speed without using a second equation.
Oh so I need to use ΔKE equation.
((.5)(m1)(Vi1)2+(.5)(m2)(Vi2)2)i = ((.5)(m1)(Vf1)2+(.5)(m2)(Vf2)2)f
and solve for either Vf1 or Vf2 then plug it back into:
Find the other final velocity, and then:
%ΔKE= 100(F-I/I)
%ΔKE= 100(F-I/I)
Good. That should do it.
(0.26kg)(1.2m/s)+0=(0.26kg)(-vf1)+(0.15kg)(vf2)
(0.312 kg m/s)=(0.26kg)(-vf1)+(0.15kg)(vf2)
(0.312 kg m/s)-(0.26kg)(-vf1)= (0.15kg)(vf2)
(0.312 kg m/s)+(0.26kg)(vf1)= (0.15kg)(vf2)
((0.312 kg m/s)+(0.26kg)(vf1))/(0.15kg)=(vf2)
((.5)(0.26kg)(1.2m/s)2+(.5)(0.15kg)(0 m/s)2)i = ((.5)(0.26kg)(-Vf1)2+(.5)(0.15)((0.312 kg m/s)+(0.26kg)(vf1))/(0.15kg))2)f
(.1872 kg m/s)=((.5)(0.26kg)(-Vf1)2+(.5)(0.15)((0.312 kg m/s)+(0.26kg)(vf1))/(0.15kg))2)
(.1872 kg m/s)=(-0.13kg)(vf1)2+(.13kg)[.0974kg m/s)+(0.0676)(vf1)2]/(.0225)
Isn't there a simpler way? Lol
((.5)(0.26kg)(1.2 m/s)2+(.5)(0.15kg)(0)2)i = ((.5)(0.26kg)(vf1)2+(.5)(0.15kg)(Vf2)2)f
(0.1872 kg m/s)+0=(0.13kg)(-vf1)2+(0.075kg)(vf2)
(0.1872 kg m/s)+(0.13kg)(vf1)2=(0.075kg)(vf2)2
SQR[(0.1872 kg m/s)+(0.13kg)(vf1)2]/(0.075kg)=vf
(2.895 m/s)(vf1)=VF2
(0.26kg)(1.2m/s)+0=(0.26kg)(-vf1)+(0.15kg)((2.895 m/s)(vf1))
(0.312 KG M/S)+(0.26kg)(vf1)=(0.15kg)((2.895 m/s)(vf1))
[(0.312 KG M/S)+(0.26kg)(vf1)]/(0.4343KG M/S)
idk..
Yes, there is if the collision is one-dimensional, which it looks like you're assuming here. Check your textbook for a simpler equation you can use for one-dimensional elastic collisions, rather than the conservation-of-kinetic-energy equation. It's simpler because it doesn't have the squared terms, so the algebra is easier to handle.
Providing the equation would have been less effort on both our parts. Thank you for the help. :)
(2.08 m/s)+1.73(vf1)=(vf2)
(1.2 m/s)+vf1=vf2
(2.08 m/s)+1.73(vf1)=(1.2 m/s)(vf1)
(2.08 m/s)=0.69(vf1)
vf1= 3 m/s(2.08 m/s)+1.73(3m/s)=(vf2)
vf2=7.27m/s
ΔKE= (-(.5)(0.26 kg)(3 m/s)2+(.5)(0.15kg)(7.27 m/s)2)f-((.5)(0.26 kg)(1.2m/s)2+(.5)(0.15kg)(0)2)i
=-1.17+3.96J-0.1872J
=2.60J
(100x2.60J)/-1.17J+3.96J= 93%
This better be right. GRRRR.
arizona1379 said:
vf1= 3 m/s
I might be mistaken, but I have studied that fv final velocity can never be more than 2iv
if vi1 = 1.2 vf1 should not exceed 2.4, do you agree?
Yeah I guess I need practice. I am having a hard time finding a good example. I haven't had math in a while so my algebra isn't very strong.
I figured you could use practice finding stuff in your book. :wink:
I get ##v_{1f} = 0.322\text{ m/s}## and ##v_{2f} = 1.52\text{ m/s}##. Check your sign convention for ##v_{1f}##. You're not being consistent.
How could both of my final velocities be positive if they are traveling in two different directions after collision?
How do you know they're traveling in different directions after the collision?
(1.2 m/s)+vf1=vf2
vf1= 3 m/s
vf2=7.27m/s
=2.60J
(v1-v2)i=(v2-v1)f
1.2-(vf1)=vf2
(1.2 m/s)-vf1=vf2
(2.08 m/s)+1.73(vf1)=(1.2 m/s)-(vf1)
(2.08 m/s)+2.73(vf1)=(1.2 m/s)
2.73(vf1)=-0.88 m/s
2.73(vf1)/(2.73 m/s)=-0.88 m/s/(2.73m/s)
vf1=-0.32 m/s)
(2.08 m/s)+1.73(-0.32m/s)=(vf2)
vf2=1.52 m/s
ΔKE= (-(.5)(0.26 kg)(-0.32 m/s)2+(.5)(0.15kg)(1.52 m/s)2)f-((.5)(0.26 kg)(1.2m/s)2+(.5)(0.15kg)(0)2)i
=-0.0133+.1732J-0.1872J
How do I know that they are not? Lol
I guess I just assumed that it's not a glancing collision. I thought the two balls bounce off each other in opposite directions, so the vf1 would be negative. No angles were given.
(v1-v2)i=(v2-v1)f
1.2-(vf1)=vf2
(1.2 m/s)-vf1=vf2
2.73(vf1)=-0.88 m/s
vf1=-0.32 m/s)
vf2=1.52 m/s
AHA.:smile:
ΔKEcue= ((.5)(0.26 kg)(1.2m/s)2+(.5)(0.15kg)(0)2)i-((.5)(0.26 kg)(-0.32 m/s)2)f
=0.1872J-0.0133J
=.1739J
100(.1739J)/.1872= 93%
Finalllyyyyyyyy:!)
Think about what happens when a bowling ball collides elastically with a ping pong ball at rest. The bowling ball is going to keep moving in the same direction as it was before because it's so much more massive than the ping pong ball. A collision doesn't have to cause the direction of its velocity to change.
If the masses are equal the moving mass stops: fv1 = 0,
if the moving mass is smaller it rebounds with max fv1 =≈ 2 iv1
if it is greater it continues in the same direction with max fv1 = ≈ 1 iv1
93.1% is not correct,
you need not find fv1: Ef2/Ei1:
the exact result is 92.8019036287 % (0.34745/0.3744) *100
:cry:
arizona1379 said:
:cry:
Cheer up Arizona, when you get more practice you you can find the result in a simple way: 4Mm/(M+m)2:[tex]\Delta E = \frac{4*.26*.15}{(.26+.15)^2}[/tex]
FAQ: Elastic Collision: Calculate the Percent Change in KE
1. What is an elastic collision?
An elastic collision is a type of collision where both kinetic energy and momentum are conserved. This means that the total kinetic energy and total momentum of the system before and after the collision are equal.
2. How do you calculate the percent change in kinetic energy in an elastic collision?
The percent change in kinetic energy can be calculated using the formula:
% change in KE = (final KE - initial KE) / initial KE x 100%.
3. What is the significance of calculating the percent change in kinetic energy?
Calculating the percent change in kinetic energy allows us to determine the efficiency of the collision. In an elastic collision, the percent change in kinetic energy should be 0% as there is no loss of energy. If the percent change is not 0%, it indicates that the collision was not perfectly elastic and some energy was lost to other forms, such as heat or sound.
4. What factors affect the percent change in kinetic energy in an elastic collision?
The percent change in kinetic energy is affected by the masses and velocities of the objects involved in the collision. A larger mass or higher velocity will result in a larger change in kinetic energy.
5. Can the percent change in kinetic energy be negative in an elastic collision?
No, the percent change in kinetic energy cannot be negative in an elastic collision. This is because the total kinetic energy is conserved, so the final kinetic energy cannot be less than the initial kinetic energy.
