Elastic collision in one dimension
The discussion revolves around calculating the speeds of a pendulum and a block after an elastic collision. The pendulum, weighing 0.5 kg and swinging from a height, has an initial velocity of 3.7 m/s calculated using gravitational potential energy. Participants explore the conservation of momentum and kinetic energy equations but face challenges in solving them without using a specific formula for one-dimensional elastic collisions, which requires a lengthy derivation. A proposed approach involves rewriting the conservation equations to express one variable in terms of another to facilitate solving for the final velocities. The conversation highlights the complexities of applying conservation laws in elastic collisions while adhering to academic requirements.
lone21
A Pendulum weighs .5kg and has a string length of 70cm swings from a horizontal position downwards to hit a block that weighs 2.5 kg and is on a frictionless plain. Calculate the speed of both the ball and the block after the elastic collision.
mgh=.5mV^2
m1V= m1V1+m2V2
conservation of kinetic energy
.5m1V^2=.5m1V1^2+.5m2V2^2
I used the first equation to solve for the initial velocity of the pendulum, which is 3.7m/s.
From here comes the elastic collision part.
I try to use both conseravation equations and substitute for one of the variables by solving for either V1 or V2 in either equation and thus substituting. However, when i try to solve it that way it ends up canceling out.
I know there is an equation for one dimension elastic collisions, but my professor says we can't use it unless we write the derivation of it, and that is a tedious thing to do and is rather lengthy.
Please help, ask questions if things are unclear
mgh=.5mV^2
m1V= m1V1+m2V2...(1)
.5m1V^2=.5m1V1^2+.5m2V2^2...(2)
You can rewrite eq.(1) as
m1v - m1v1= m2v2...(3)
Similarly you can rewrtie eq.(2) as
m1v^2 - m1v^21= m2v^22..(4)
From 3 and 4 you can get
(v - v1)/v^2 - v1^2= v[/SUB]2[/SUB]/v[/SUB]2[/SUB]^2
After simplification you get
(v + v1) = v2
Substitute the value of v2 in equation (1) and solve for v1.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
