Elastic Collision: Find V1', V2' with M1, M2, V1, V2
In the discussion on elastic collisions, participants analyze a scenario involving two colliding objects with known masses and initial velocities. The equations for conservation of momentum and kinetic energy are used to derive final velocities, V1' and V2', resulting in V1' = -7 m/s and V2' = -1 m/s. A question arises about manipulating the equations to solve for initial conditions when some variables are unknown, specifically asking if it's feasible to determine mass M2 and initial velocity V1 with given final velocities. The consensus is that it is challenging to solve for three variables with only two equations, suggesting that additional information or constraints are necessary for a solution. The discussion highlights the complexity of algebraic manipulation in collision problems.
Ajwrighter
1. Two objects collide M1 = 1kg M2 = 3kg V1 = 2m/s V2 = -4 m/s V1' = ? V2' =?
2. PEi = PEf m1v1 + m2v2 = m1V1' + m2v2' KEi=KEf same as (1/2)(PE^2)/m
3. PEi = PEf ----> 2 - 12 = -10 ---> v2' = (-10 - v1')/3
KEi = KEf ----> 4 + 48 = 52 ----> 156 3Vi^2' + V1^2' + 20v' +100
4. V1' = - 7 V2' = -1
KEi = 2J + 24J = 26J KEf = 24.5J + 1.5J = 26J
The real Question: I tried to manipulate the problem with algebra but to no ends. So here is my question, how do you obtain V1 or V2 with (not V1' or V2') Can you obtain your numbers if let's say you have
1. Two objects collide M1 = 1kg M2 = ? V1 = ? V2 = -4 m/s V1' = -7 V2' =? What format would you use to solve this. I tride using the same equations but I can't seem to manipulate the algebra to do what I want. I keep getting either really small or really large numbers.[/
I don't understand, you have 3 variables and two equations? Also your equations are almost unreadable.
I just zipped by to show that i can do it and have gotten the answer. Was wondering if there was a way to obtain an answer if the variables where miss matched . so instead of the equation asking for V1' and V2' (like stated above) it would be asking for M2, V1 and V2' =?
You can do it? Show me please!
I think it's impossible when you have only two equations for three variables. (Unless you can eliminate two variables at once somehow...)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
