Solve Elastic Collision: Find Velocity & Direction
To solve for the missing velocity and direction of one ball in an elastic collision, use the conservation of momentum and energy principles. The total momentum before and after the collision must remain equal, which can be expressed in terms of the x, y, and z components. A vector diagram can aid in visualizing the directions of the velocities involved. By calculating the known velocities and applying the conservation equations, the unknown velocity can be determined. Understanding the 2D or 3D nature of the problem is crucial for accurate calculations.
thereddevils
Given two balls of the same mass of known velocities and known direction (before and after collision) , only one of the ball is not given its velocity and direction before collision and i am supposed to find them .
As for the velocity , just take the sum be4 and after collision and evaluate the missing one .
How about the direction ? Do i draw a vector diagram ?
To find the velocity remember Momentum and Energy are conserved.
Hard to understand from your question, but it sounds like they are both traveling different 2D or 3D directions before collision, thus when they collide you can remember that Momentum is conserved in the x, y, and z direction. so:
\Sigmapx=\Sigmap'x
\Sigmapy=\Sigmap'y
\Sigmapz=\Sigmap'z
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
