Elastic Deformation through compression (stress)
The discussion centers on calculating the compressional stress on the forearm during a car crash, given the effective mass and cross-sectional area of the bones. The total cross-sectional area of the radius and ulna is 2.16 cm², and the arm decelerates from 81.9 km/h to rest over 7.72 seconds. Using the formulas for force and stress, the calculated stress is approximately 25.65 million Pa. Concerns about whether to halve the cross-sectional area due to the mention of two bones are addressed, confirming that the total area is already provided. The final suggestion is to check significant digits for accuracy.
fanie1031
1. The total cross-sectional area of the load-bearing calcified portion of the two forearms bones (radius and ulna) is approximately 2.16cm^2. During a car crash, the forearm is slammed against the dashboard. Tha arm comes to rest from an initial speed of 81.9km/h in 7.72 s. If the arm has an effective mass of 1.88kg what is the compressional stress on the arm? Answer in units of Pa.
2. Stress=F/A ,
additional
F=ma
Vf=Vo+at
3.
Conversions
A=2.16cm^2*1m^2/10^4cm
=2.16e-4m^2
Vo=81.9km/h*(1hr/60mins)(1min/60s)(1000m/1km)
=22.75m/s
F=ma
a=(Vf-Vo)t=-2.94689.
I assumed I could make it positive since the problem's context is in forward motion not retardation.
F=1.88kg*2.94689
=5.540kg*m/s^2
P=F/A
P=5.540kg*m/s^2/2.16e-4
=25.648.8677N/m^2= same in Pa.I feel like I put in the appropriate conversions and formulas but when I plug in the answer, I'm told I am wrong. Does it have to do with the fact that it mentions "two forearm bones" in the beginning? If it is, where do I half the cross sectional area?
I hope I'm not too far off.
Your method looks fine. Units are OK.
Check the significant digits is about all I can suggest.
Your concern about 2 cross sections should be allayed by the statement of total cross section.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
