What is the relationship between force and potential energy in elastic systems?
  • Thread starter Thread starter flazer
    Elastic Energy
The discussion focuses on understanding the relationship between force and potential energy in elastic systems, specifically in the context of Hooke's law. It highlights the need to calculate average force when determining work done by a spring, as the spring force is not constant but varies linearly. The average force during stretching is derived as F_average = kx/2, which simplifies the calculation of work done. The potential energy is represented as the area under the force versus displacement curve, prompting a comparison with a constant force that would yield the same area. This explanation emphasizes the significance of average force in the work-energy theorem for elastic potential energy.
flazer
Who can explain me why we need to find an average force in proving theorem work=elastic potensial energy?
If elastic potential energy (lets call it U) is the only energy involved, then W = - U. Remember, in using Hookes law, that if W = force times distance, the spring force is not constant, so you need to use calculus to find the work, or simply note that the spring force varies from 0 to its max value of kx.
I do not know calculus so please can someone explaın me wıthout usıng calculus
If the initial force in the spring is 0, and the force varies linearly with x (F=kx) as it is stretched, then at its maximum point of stretch , the force is F=kx, where x is at its maximum. So the average force during that period of stretch is just (0 + kx)/2, or F_average =kx/2. Now use that value of force in your work equation to find the work done by the spring.
On the graph of F vs. x, the potential energy is equal to the area under the curve between 0 and x. What constant force would have the same area underneath?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
