Electric cable in a Vertical Tube: Estimate the Conductor Temperature
The discussion centers on estimating the temperature of an electric cable within a vertical steel tube exposed to sunlight. The user initially applies a heat balance equation to calculate the maximum temperature of the tube, factoring in solar radiation and heat loss. They express concern over their method for determining the conductor's temperature over a full day, suspecting their results are unreasonably high. After some trial and error, the user indicates they have found a solution to their problem. The conversation highlights the complexities of thermal calculations in engineering applications.
stevekho
Hello,
I have an electric cable in a vertical steel Tube. I estimated the temperature that will reach the JTube exposed to sun radiation.
I came with these equations
QCable+ Qsun - Qradiated = mc( Tfinal - TAmbient)
where QRadiated= k.A.(Tfinal^4-TAmbient^4), QSun=234 [W/m^2] * A
A=Area of the Tube
K=Radiation constant= 4E-8
m=Mass of the tube
c=473 for steel
I finally find for a day the maximum Temp that will reach the Tube ( Resolved a quartic Equation with Tfinal as an unknown knowing that Tambient=34 for instance )
However I want to know what temperature will reach the conductor ( after a day =86400 Secs)
What I thought was
For each t ( from 0 to 86400 secs)
QCable = mc( Tfinal - TAmbient) - Qsun + Qradiated
For each t, I know the right side. I Find QCable and then Divide it by the Thermal Mass to find the Temperature :/
However I find extremely large Results so I think it might be wrong ( it shouldn't be bigger that 90 Degrees)
Hope someone will be able to help me because I am really losing Hope...
Thank you very much Guys
Steve
Ooooooook I found it :)
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
