Why Is the Electric Displacement Field Important in Understanding Capacitors?
The electric displacement field is crucial for understanding capacitors because it addresses the flow of displacement current during charging and discharging, which allows Kirchhoff's first rule to hold true. In a capacitor, while no current flows through the dielectric, a displacement current is considered to flow, ensuring continuity in the circuit. This displacement current is defined by the rate of change of the electric displacement field, linking it to the capacitor's voltage change over time. The concept is integral to Maxwell's equations, particularly in the context of the Ampère-Maxwell law. Understanding this field enhances comprehension of how capacitors function in electrical circuits.
Vanush
Can someone please post a problem/situation outlining the motivation / usefulness of the electric displacement field? (Particularly with a capacitor) I'm having trouble understanding the concept and information is sparse on the internet.
Hi Vanush! :smile:
For electric displacement field in a capacitor, this (from the PF Library) may help:
Displacement current:
No current ever flows through a functioning capacitor.
But while a capacitor is charging or discharging (that is, neither at zero nor maximum charge), current is flowing round the circuit joining the plates externally, and so there would be a breach of Kirchhoff's first rule (current in = current out at any point) at each plate, if only ordinary current were used, since there is ordinary current in the circuit on one side of the plate, but not in the dielectric on the other side.
Accordingly, a displacement current is deemed to flow through the capacitor, restoring the validity of Kirchhoff's first rule:
I\ =\ C\frac{dV}{dt}
and this linear displacement current I (which might better be called the flux current or free flux current) is the rate of change of the flux (field strength times area) of the electric displacement field D:
I\ =\ A\,\widehat{\bold{n}}\cdot\frac{\partial\bold{D}}{\partial t}\ =\ A\,\frac{\partial D}{\partial t}\ =\ C\frac{dV}{dt}
which appears in the Ampére-Maxwell law (one of Maxwell's equations in the free version):
\nabla\,\times\,\bold{H}\ =\ \bold{J}_f\ +\ \frac{\partial\bold{D}}{\partial t}
Note that the displacement alluded to in the displacement current across a capacitor is of free charge, and is non-local, since it alludes to charge being displaced from one plate to the other, which is a substantial distance compared with the local displacement of bound charge in, for example, the presence of a polarisation field.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
